Ads coilover and lift springs
Fifty
ADS racing suspension coilover up front, and today, will be lift springs and remote reservoir shocks out back. As well as suburban z71 bumps.
It’s going to lift the vehicle about 2 inches I think.
This is a 2015 Yukon Denali XL.
(And of course the little fooler plugs)
Call ads and tell Tyler that OConnor sent you. Get the red beard discount.
Trey Hardy
How do you like the ride with these? I like my icons a lot but there kinda stiff at times I wish they had the Dsc Adjuster on them
F
Fifty
The rears.
If I off-roaded a lot of get comp adjusters because it splits the valving and is better for heat and cavitation.
If you don’t, just get shocks from a company that will custom valve them and valve them for your use.
I’ve found I don’t change my other vehicles with clickers that much. Unless there is a major weight add or I’m going to drive in the street for a long drive to a trail.
F
Fifty
Here are a couple better pictures. I ran these spare multimatics temporarily for about 300 or so miles. Those shocks are such trash. I thought “maybe they aren’t as bad as I remember”
Nope. Junk.
Also it’s hard to see but the ADS reservoirs aren’t clocked/angled a little bit for extra frame clearance. So they are side specific.
Also, notice that the reservoir port is at the bottom. This forces the oil to pass through the piston during compression instead of escaping to the reservoir when the axle shaft volume fills the shock body.
So better compression dampening control which is needed on heavy vehicles and the heavy rear axle on the 6.2l Yukon Denali xl.
olyelr
Elk Rapids, MI
Nope. Junk.
Do those shock actually suck or do they just suck when you put them into an application that they wernt designed for? Just curious. Those are for zr2’s arnt they? A much lighter rig.
F
Fifty
They just suck.
Skinny shafts… a weak main oil seal cap.
They don’t come with much nitro pressure… they over heat.
The valving is ok for crawlers but is terrible for any high speed stuff which the truck is advertised for.
I am acquaintances with someone on the design team and that person said the shock was designed and “valved” (you have the cup so it’s not just a regular valve) to be run with the SPC bump as if it’s a secondary shock.
But the truck does not come with that from the factory and it was years before those parts were released.
Just a lot of bling…
olyelr
Elk Rapids, MI
They just suck.
How are the new at4x/zr2 shocks on the full size rigs? Same bul*sh*t different day?
F
Fifty
Probably. The new Silverado zr2 seems to have the gmpp zr2 multimatics…
Which are eh… better…
Less travel than stock which is odd. And NOT what Chad hall runs on his truck
The threaded perch ones on the truck are the hall truck, the ones on the table are the gmpp final finals.
The at4 if it’s not computer controlled are probably 1.9” diameter made by whomever ifp shocks…
olyelr
Elk Rapids, MI
I thought the at4X would have the same as the zr2.
F
Fifty
So it does. I didn’t know that.
I wouldn’t spend the money on it for the shocks.
That motor though… I love the 6.2 on my Yukon.
F
Fifty
Well. It’s a lot of money for very little travel.
As long as Gm uses these overly wide frames, they won’t be able to run long control arms. And with that, low wheel travel numbers.
Idk why they do it… raptor 13/14, TRX 13/14, Silverado zr2 8/10, colorado zr2 8/10, atx4 8/10
And shocks that blow oil seals when you look at them wrong. I just perused the Silverado zr2 forum and they are having the same shock issues the colorado have.
Sad. The motor with the new interior could be nice. Lockers stock…
Do you know if the atx4 rear axle is full
Float or semi float?
olyelr
Elk Rapids, MI
I honestly dont. Im a ram truck guy lol…dont pay much attention to the gm’s. But i would be extremely surprised if it was full float.
F
Fifty
I just figured with Dana doing that unit bearing floater on the TrX…
Maybe…
Then again, the Denali Yukon XL axle is the 9.75? What ever it is is bigger than the 5.3 which is already a fairly stout axle.
We have a zr2 colorado, Yukon den xl and a trx. All three have surprisingly stout axles for oem. The axle guy that I know (I don’t do gears) did gears o my zr2 a few years ago. The d46hd/d46/d44hd/m220 depending on what brochure from Dana you read.
He was pretty impressed with it and said the design and build of it was similar to a regular d60.
It has taken a beating with 35’s and a 4800# truck and some high speed trail work.
Korbin_A
