Sub box pic's needed
Dubbin
Minot AFB ND
so i'm trying to convince the wife to let me put subs in her tahoe, thing is she doesn't want to loose cargo space. Anybody have pictures of the Q form box installed?? thanks
Sir-Lancelot
South Carolina
Here you go. Plenty of room.
lol
crmzendrgone
M town Arizona
That looks photoshoped.^^^
---------- Post added at 04:44 PM ---------- Previous post was at 04:41 PM ----------
Maybe, Maybe, huh you like!!!
---------- Post added at 04:46 PM ---------- Previous post was at 04:44 PM ----------
maybe
Tahoewhat
Ballin' on a Budget
TX
Heres a pic of my custom made box. Cant really put anything else back there. If i have to use it, i just undo and it comes out..
AV8ter
You make that box mike? Those tens, right? I just designed a box for two ported tens back there and it looks completely different. I got both the subs and the ports firing up.
How does it sound? Can you compare it to anything? What you running on them for power?
TnTahoe
TN
JK did you cut a hole in your floor or something? I cant pircture how you have the subs in like that with enough mounting height
JKmotorsports
Austin, TX
Cut out an opening in the floorboard and welded a metal frame/housing for the sub enclosure.
You may notice the enclosure is off center a bit. Had to do this because the fuel filler neck to the gas tank ran down the driver side and it was easier to just offset the enclosure rather than modifying the fuel filler tubes.
Without and with the stock cargo mat:
And if you want a place for the amps, here's a pic of an amp rack I built underneath the 2nd row. I used speaker grille cloth for the removable covers so any heat from the amps can escape:
TnTahoe
TN
damn nice build pics, is the box metal that sits in the hole? and very curious to how it sounds
briannorris
