2021 Yukon AT4. Climate control buttons stopped working
JohnAT4
Weird issue started yesterday. When I start my car, the temp on AC is set on "HI" and on Max defrost for the vents (even if I had AC on at 70 when I turned it off). The manual knobs on the center stack for adjusting temp do not work (but do display the temperature). The knob for changing fan speed do not work. The manual buttons for changing the vent levels do not work. The seat ventilation/heat buttons stopped working all together. BUT, fortunately, if I go to the infotainment screen for Climate, I can change settings on the screen or it would have been a HOT 4 hour drive today. I will probably just have to take it to dealership.... just hoping someone might know an easy-ish fix. Thanks
MAnderson1977
@JohnAT4 The exact same problem started happening earlier this week with my 2021 Yukon. Did you find a solution to this?
MAnderson1977
To follow up.... took my Yukon to the dealership and they determined that part of the control panel was defective and needed to be replaced. It was the part that contains the knobs that adjust the temperature.
corima
happened to mine when it was a about 6 months old. They had to order parts, took a week but they gave me a loaner.
J
JohnAT4
Sorry for delay in getting back. Dealer says it was the HVAC control module (same part yall mentioned). They ordered it at the end of March but is still backordered unfortunately.
J
JohnAT4
Just an update. GMC still has this HVAC control module on backorder. It has been 3 months. There was supposed to be an update on 6/16 from GMC and the dealer reports no update was given. I happened to pick up a used unit from a salvaged car on Ebay, but dealer told me today that once the units are "coded" to a particular car they cannot be transplanted to another car. I wouldn't mind selling this car at this point, because who wants a car under warranty that cannot be fixed, but also don't want to take a monetary hit for selling a car that should be fixed under warranty.
J
JohnAT4
I am still waiting to get this problem fixed. Dealer and GMC say "No ETA" on HVAC control module.
Chad G 1979
Man, that stinks. How long has dealer had it so far? Still have a loaner?
J
JohnAT4
It does stink but I have been driving the Yukon. It drives fine... I can control AC with the infotainment screen. But remote start doesn't cool the car, seat ventilation doesn't work, and whenever I start the car it blasts hot air until I can adjust the settings with the infotainment screen. I know... first world problems for sure. But it eats at me
WalleyeMikeIII
Sunny and Snowy Minnesota
Does Google Assistant let you control it? "Hey Google, Set the Air Conditioning to 71"
May ask to speak w/ the service manager at the dealer. Would think GM would route a part for an already built vehicle to get it fixed over one on the line...but possibly hasn't been properly escalated.
Stbentoak
l highly doubt it….
GM is hand to mouth with suppliers now, they would never jeopardize stopping the line over a parts shortage, as sad as that may seem.
I was missing a part this spring that was on a perennial out of stock situation. I escalated it as far as it made sense and they just said there are none out there. But the line continued on a daily basis. The only way I fixEd the situation was by getting the GM part number and calling dealers individually. There is inventory out there but it is hidden to the system as dealers are protecting it for their customers. Finally found one that would sell it to my dealer to get my vehicle fixed.
J
JohnAT4
I have not tried the google assistant idea.... I will look into it. I have discussed with dealer service manager... pretty much silence at this point. GMC "Part delay team" emails me every 4 or 5 days with an canned email saying "We just checked and No ETA for your part"... thanks for your understanding etc.
J
JohnAT4
I may have mentioned above but I bought the part online from a salvaged vehicle on ebay... because i apparently thought parts could be interchanged between vehicles. I was wrong because they are VIN locked from factory and non-transferable. I did see a video on Youtube about EEPROM reprogramming to re-code the part to allow it to be used... but I would definitely brick my car because if I was dumb enough to think parts could be interchanged, I am too dumb for that procedure
6point2lovelifers
