What's Wrong With Your Yukon/Tahoe Today? ...And How Long Has This Been Happening?
Chad G 1979
Where does it sound like its coming from? Front or rear? Going in straight line or turning in either direction? 2wd or 4wd?
ProfeZZor X
ProfeZZor X
High Country
It definitely resonates from the center of the vehicle if you're going down hill. You can hear it clearly bouncing off the wall next to me. I thought it might be the exhaust touching a metal shield or cover plate of some kind. The noise stops once the vehicle is leveled out on flat ground.
WalleyeMikeIII
Sunny and Snowy Minnesota
Do you have air ride? Maybe the compressor?
Chad G 1979
I wonder if something is loose underneath and when your at an angle it causes things to touch and cause vibrations. Diagnosing this may be hard to do without parking on an angle and crawling underneath and look around to see if anything obvious is going on.
ProfeZZor X
ProfeZZor X
High Country
I don't have the Adaptive Air Ride, just the Magnaride. And the sound is coming from underneath the center of the vehicle, not the 4 corners. I'm at the dealership now, and showed them this video too.
ProfeZZor X
ProfeZZor X
High Country
It could be the heat shield vibrating against the exhaust. Or something comperable.
Moben
The chrome trim and steering wheel bowtie let sunlight glare in my eyes on my 22 tahoe. parts guy says they make trim in black but wouldnt guarantee it would fit. Anybody else have this problem?
todayusay
not the same thing, but our 21 Yukon had this going on when we sold it
that should be pretty easy to diagnose once it starts doing it...especially since it does it when stationary...my only question would be if it does it in park when at that angle or does it have to be in gear?
ProfeZZor X
ProfeZZor X
High Country
Went to the dealership yesterday and they gave me the oil change I was suppose to get last Thursday. They also surprised me and replaced the crooked AT4 black badging on my passenger door.
Brand0n
I had the greasy line on my drivers window. If you shine a flashlight into the door from the top you’ll likely see some white grease on a joint in upper part of the door. I just wrapped a long flathead screwdriver with a paper towel and cleaned it off, wipe the weatherstrip and you are good to go. No more greasy line on the glass!
Did you do this on the top or bottom of the window? Scrubbed dark grease out of 3 of 4 window seals but still getting some on the drivers glass. Wish I would have caught before the tint went on.
JLMBT
To be honest, I haven't touched my AM/FM radio since I got my Yukon. I've been using the blutooth and satellite radio 100% of the time. What annoys me is when I switch from blutooth to listen to the satellite radio, then turn off the vehicle and exit. When I return and start the vehicle, it reverts to the blutooth instead of satellite. And that "tab" is too tiny to switch between modes... unless there's a shortcut on the steering wheel I hadn't figured out yet.
Check under settings in your infotainment system, then vehicle then there are some options if I remember for convenience options...there is something there to help you with some of your concerns...
Truckman98
My 21 HC Tahoe had service steering column on way to firehouse. Next morning it was gone and never came on.
Service transmission came on. I was at a light and the truck shut off on me. Started right back up. Next day no message displayed. Driving home, I got to another stop light, the truck shut completely off. No lights, no power. I got out to open hood so people can go around me, truck auto locked and I went back in and the truck started up. No clue. Might need computer updated?
Drove back and forth from Florida to Chicago. No problems.
66 Galaxie
With the random electrical symptoms my first thought is a bad battery or battery connection.
Newer vehicles are very sensitive to battery conditions.
Truckman98
Uh,....yea...... Would one of you old guys chime in on this?? :angels25:
L
i had it at the dealership yesterday. Couldn’t find anything and no codes. Said battery was fine. I’ll probably just end up changing the battery soon anyhow and see if that continues.
ASG-MikeS
