Chad G 1979
- Joined
- May 6, 2022
- Posts
- 527
- Reaction score
- 327
Where does it sound like its coming from? Front or rear? Going in straight line or turning in either direction? 2wd or 4wd?
It definitely resonates from the center of the vehicle if you're going down hill. You can hear it clearly bouncing off the wall next to me. I thought it might be the exhaust touching a metal shield or cover plate of some kind. The noise stops once the vehicle is leveled out on flat ground.Where does it sound like its coming from? Front or rear? Going in straight line or turning in either direction? 2wd or 4wd?
Do you have air ride? Maybe the compressor?It definitely resonates from the center of the vehicle if you're going down hill. You can hear it clearly bouncing off the wall next to me. I thought it might be the exhaust touching a metal shield or cover plate of some kind. The noise stops once the vehicle is leveled out on flat ground.
I don't have the Adaptive Air Ride, just the Magnaride. And the sound is coming from underneath the center of the vehicle, not the 4 corners. I'm at the dealership now, and showed them this video too.Do you have air ride? Maybe the compressor?
It could be the heat shield vibrating against the exhaust. Or something comperable.I wonder if something is loose underneath and when your at an angle it causes things to touch and cause vibrations. Diagnosing this may be hard to do without parking on an angle and crawling underneath and look around to see if anything obvious is going on.
Did your dealer find anything out?It could be the heat shield vibrating against the exhaust. Or something comperable.
They removed the metal wire coat hanger from the drive shaft.Did they figure out what the rattle sound was coming from?
Howd you manage to pick one of those up and get it around the driveshaft? And at least it was an easy fixThey removed the metal wire coat hanger from the drive shaft.
Uh,....yea...... Would one of you old guys chime in on this??Howd you manage to pick one of those up and get it around the driveshaft? And at least it was an easy fix
Did you do this on the top or bottom of the window? Scrubbed dark grease out of 3 of 4 window seals but still getting some on the drivers glass. Wish I would have caught before the tint went on.I had the greasy line on my drivers window. If you shine a flashlight into the door from the top you’ll likely see some white grease on a joint in upper part of the door. I just wrapped a long flathead screwdriver with a paper towel and cleaned it off, wipe the weatherstrip and you are good to go. No more greasy line on the glass!
The wire in the driveshaft is an old prank back in the '60's....Uh,....yea...... Would one of you old guys chime in on this??![]()
Check under settings in your infotainment system, then vehicle then there are some options if I remember for convenience options...there is something there to help you with some of your concerns...To be honest, I haven't touched my AM/FM radio since I got my Yukon. I've been using the blutooth and satellite radio 100% of the time. What annoys me is when I switch from blutooth to listen to the satellite radio, then turn off the vehicle and exit. When I return and start the vehicle, it reverts to the blutooth instead of satellite. And that "tab" is too tiny to switch between modes... unless there's a shortcut on the steering wheel I hadn't figured out yet.
LUh,....yea...... Would one of you old guys chime in on this??![]()
i had it at the dealership yesterday. Couldn’t find anything and no codes. Said battery was fine. I’ll probably just end up changing the battery soon anyhow and see if that continues.With the random electrical symptoms my first thought is a bad battery or battery connection.
Newer vehicles are very sensitive to battery conditions.
