New coils for 22s
Asaf Fried
Hi everyone,
I bought a 2016 SLT with aftermarket 22's.
The struts and shocks are done at 110K and I am putting new Bilstein 5100 and new springs. I would like to use this opportunity to put springs that are better suited for the 22's - does anyone know what stock/aftermarket I should use ?
Currently I have standard (6/7HC rpo) front suspension and Nivomat (ZW7) in the back
Thank you
olyelr
Elk Rapids, MI
Coils better suited for 22’s? These rigs came with 18’s/20’s/22’s and i dont believe they changed the suspension for any of them. What makes you think you do? You want to lower, lift, or leave the same height?
A
Asaf Fried
Thanks for replying. Same height. Not really sure why, but there are many coil spring options on AC Delco website and many RPOs
cnunez
Following, as I was wondering if anyone upgraded their front coil springs after doing a drop.
I did bilstein 5100s and factory springs and it still seems like the front end is alittle bounce. 2016 denali with magride delete and I did the belltech 2/4 drop with front drop spindles.
Brad32486
Saint Paul, MN
I'm really debating right now between 2" drop spindles or 1" lowering springs. I know the geometry will change between those two options, but are you happy with the spindles and the look? I currently have front stock height and rear is dropped about 2.5" to level it. It does sit level with the ground, but that front wheel well goes a little higher, so I don't like the gap. Just don't know if 2" lower up front might be too low.
olyelr
Elk Rapids, MI
From what i have read, the 2” spindles only net a drop of 1.5” or less in many cases….how in the hell that is even possible i have no clue, but that seems to be what everyone has been reporting.
Smokin Denali
