AT4 lift
Fernando Magana
We have a non air ride yukon slt and successfully had the rough country 2" front 1" rear kit installed on it even though the fine print says it does not fit gmc models. I gained 1 3/4" in the front and 1 1/4" in the rear. Final result is not level (3/4" higher in the rear) but I'm happy with the results
Does your Yukon have the Magnetic ride? I called RC and they say the 2" leveling kit won't work with Magnetic Ride equipped vehicles.
sanman28
SLT’s are not mag ride equipped. Here is a level for mag ride. I should add that there seem to be many people running non-mag ride advertised lifts on mag ride equipped Yukons.
olyelr
Elk Rapids, MI
I put a 1.5” lower strut spacer kit on my wifes high country with no brackets for magnaride. No issues at all. Hell, i couldnt even find any sensors in the first place…woulda used some left over brackets i had.
sanman28
Yup. Was thinking about your info when I typed that.
olyelr
Elk Rapids, MI
Anybody have pics on where the sensors are located? I mean, i did it on the garage floor with jackstands so i couldnt really get down there to see very well….but i legit couldnt find them. I assumed they didnt have them anymore.
ProfeZZor X
High Country
The information about all of these various leveling and lift kits are confusing. Some are for certain vehicles (Chevy) but don't mention others vehicles with the identical parts (GM), some are only for 2021 but don't mention 2022, and so on.
All I'm looking for is a leveling kit for my 2022 AT4 Yukon w/MRC... I figure adding the kit will be much easier on the amount of metal shaving I'll have to do on the fenders to fit my 24x14's.
sanman28
Here
That being said….my AT4 is only about 3/4ish lower in front….a 2” would probably mean looking for a 1” rear. Other members have had luck with the RC 2/1 even though says not for MC
olyelr
Elk Rapids, MI
I dont think a leveling kit is gonna save you much trimming at all. Honestly probably save you none. Maybe a 12” lift, but not a leveling kit.
ProfeZZor X
High Country
ProfeZZor X
High Country
Had my 3" Ready Lift kit installed today. It went smoothly without a hitch (no pun intended), but it does feel a little weird driving just a little bit higher. All of my mirrors had to be readjusted to compensate for the additional height, and that extra 3 inches getting in and out takes some getting use to. It barely clears my garage by one inch.
Overall the kit will serve its purpose for why I added it, so that's all that matters.
DomT
Has anyone found a lift/leveling kit for the Yukon AT4?
Ready Lift now has a 3” lift for the AT4 to accommodate the Magnetic Ride.
thill466
Looking at this same kit for my wife's 22 at4 since none of the levels seem to state they're compatible with MRC on a 22 and up. Do you have any photo's of the cv angles with the 3 inch lift on? Thats my only concern without dropping the diff that i may be replacing CV's every 30k miles.
tenminutes
Very surprised more people haven't jumped on this Readylift SST 3" kit. I really want to see an AT4 Yukon with stock 20's on 35x12.50's with this. And no wheel spacers. Anyone ever seen an example of how that setup came out?
Al559
I think the lift rides great. At least as good as any other I’ve had over the last 26yrs of driving.
I know this is an old post but sanman28 what size is your tire and wheel combo? Do your tires rub on any pinch welds or plastics at all? And how has it been working out since you installed the 3 inch kit? Beautiful truck btw
schafer98
