Running Boards
v8doctor
I have a 2018 Tahoe premier, 25k miles. The drivers side running board will only extend some of the time, never know when, sometime I can open the rear door and it will work fine but from the drivers door, I never know if it is going to extend or not. I think there has to be some kind of actuator switch associated with the doors but I can't find any information on location . Anyone have any knowledge about this. The passenger side works fine every time, just drivers door activation that is the problem. Thanks
markni12301
Have you thoroughly cleaned and lubed all the hinged joints? There are many YouTube videos on this common problem. Use PB Blaster and wire brushes and air compressor blower. Recommened to clean and lube as often as every oil change.
I would just be sure it's all clean and lubed before other extensive diagnosis and possibly costly repairs.
Conedaddy
