Escalade Cluster in NNBS!
Doug118
Thanks Doug. Looks like I'll have to hunt one down from those years
Do a little research because I’m not 100% that 2009 was the last year they didn’t have oil or voltage. I just know mine came from an 08 and does not have it. Or just try to buy 12-14 since we know from Rocketman that the 12 has it for sure
5StarG3neral
I pulled up the owners manual for each year. The 07-08 do not have the oil pressure or voltage readings. 09 and up all have it. I've sourced one from a 2012 that I'm picking up tomorrow and throw it in over the weekend to see if this works. I also noticed the 07/08 clusters dont have the outside temp reading or the compass.
I don’t know what GM was thinking there. Good luck, sounds like you have it figured out. And I learned something new.
Doug118
Hopefully the plugs are the same. Don’t see why they’d change them but GM has done dumber shit than that
07-08 didn’t have DOD so they probably knew they wouldn’t have oil issues
5StarG3neral
**Update** Got the 2012 cluster in and now have my oil pressure, voltage, compass, and outside temperature all displayed.
Weird thing I noticed even with the 07 cluster in was my engine temp gauge. I find it dips down at idle at times down to 0 even though I'm at full operating temp. I start moving she it climbs up to where it should be.
Any ideas? Everything else on the cluster functions 100% as it should and I've checked all of my connections multiple times.
Joel_S
I’m about to have to re-solder the cluster in my 07 for a 3rd time and at this point I may just do an Escalade one. Anyone who has a dash bezel they’d be willing to sell as well as harness, I’m happy to buy. Hell maybe if I can get a clean bezel I’ll take it to a few local plastic molding places and see the cost of copies.
Jurvay12
Hey Everyone, I’m doing the Cadillac cluster swap in my nnbs. I wired it in and everything works EXCEPT my fuel economy, and fuel range. Things are missing on digital gauge. Anything will help
Thanks!
Kaynan
DHaz2007
Nice! I'm definitely interested [emoji848]
Hey bro Dave here. Are you still making these? I would love to buy one send it to you however this works bro! This is so badass!
Jeffv
I just put my harness together and got my cluster installed but don't see the oil pressure and voltage on the DIC after cycling through. Any ideas?
Hi did you ever get the part number? I have the escalade pigtail and im trying to build my own harness also but been looking for weeks cant figure out the connector part number its driving me crazy thanks in advance.
I don’t have the part number but the member who sold me the one I used to make my harness told me they’re not available anymore. Maybe you can get one from a wrecking yard or hard wire to the Escalade connector.
Jeffv
Thanks for getting back to me i think S20B-AIT2G-2A2BK might have been the part number but dont think they make it anymore which stinks i was hoping to not have to cut off my chevy plug so i can switch back easy.
67RS427
I had trouble finding the correct part as well, this might help though since you can just splice right into the old one...
67RS427
Thank you, yea thats my last resort wanted to be able to swap between clusters so trying to figure out some sort of plug option
I've tried before but you can also try to contact https://www.mouser.com support and see if they can help. Give them the connector number on that picture and see if they can find the other end of it. Their support is pretty good...
Jeffv
Thanks for all your help i did contact them a few weeks ago they are very nice and helpful. Think we came to the conclusion that the part was only made for a short time and is not produced any longer. I also contacted jst who we think made the plug they sent me something from japan but it wasnt the right part.
Conedaddy
