Sparksalot
Bastrop County, Texas
I pulled a wheel off thethirdtwin to check data on the back side. While I was there….
I confirmed a 17” wheel does fit. The spare from thecopcar doesn’t look bad.
I may chose 17x9 in the future to gain more sidewall for airing down.
Bigkevschopshop
Northside H-Town
The tire choices for 17s are better for offroad tires honestly, and ride offroad with more sidewall is far better, your kidneys will thank you. haha.
Jeff_
Scottsdale, AZ & N. Idaho
the windshield was replaced on mine as part of the sale, but it was done at the dealership.
But do you have the lane assist feature in your windshield that they would need to re-calibrate?
And do you also have tires that are larger than a 265/65/18?
Because that seems to be safelite's issue...
Sparksalot
That’s the funny skidding car button, right?
Tires are 285/65/18, so same basic height.
Sparksalot
I’m also looking at options for recovery hooks and possibly a pushbar.
I have a set of hooks already from theothertwin. They slide right into the frame. The fascia needs to be opened up in some fashion.
Any of y'all need/want a Corsa cat-back for your 62.L XL or Burb?
jd08
Jackson, WI
Removed the chrome trim on the running boards to see how black running boards would look.
Now the question is, which looks better? Black or chrome?
jd08
Jackson, WI
Still liking the black running boards and the wife never notice. Now I will wrap the chrome pieces in black vinyl and put them back on.
Today I swapped out the black/red center caps for some black/chrome ones.
Also swapped out the plastic skid plate for some oem aluminum ones.
Had a little fun… Have to adjust the LEDs behind the grille a little bit.
koomie98
