A/C question
Jeremy4601
Semmes, AL
Apologies if this post is in the wrong category.
Having a/c issues. Obvious leak as a charge would only last a day or two. Paid a shop to diagnose it. Rear evaporator is busted and leaking. Quote was $1000 (everything seems to cost $1000 these days). Hot as it is here on the gulf coast right now, I quickly scooted on down the road to start googling and YouTubing. Found some good DIY videos but it still looks daunting to me. I found another shop that will do the work for $400. But I have to buy the evaporator… which brings me to my next hurdle. I’m finding several different evaporators for my Tahoe. I don’t know which is the correct fit and the shop says they have to dig out the old one to know, then they may not be able to get it. Apparently getting parts is a problem?
Anyone know of a way to determine which evaporator I need w/o tearing this thing apart first? I’ve got a 2002 LT Tahoe / 5.3.
Get the last eight of your VIN to Rene and he can look it up. @915_Tahoe
I only show one rear evaporator core for your vehicle, 12477713/16-62105
I'm good, Rene is better!
With a set of manifolds and a vacuum pump from Harbor Freight, you can do this repair yourself. Also had to buy an adapter to better puncture the cans to add refrigerant from Amazon or O'Reilly Auto.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Gm#12477713 $369.48
Discontinued
S33k3r
Dallas, Texas
My mechanic wants $1k just for the labor, and about $600 for the parts. And I know he is not scamming me. Then I found videos on YouTube where they do some cutting and come in from the front. Let me know if you want me to share them. I am uncertain what I am going to do at this point, myself.
Matthew Jeschke
Sahuarita, Arizona
The evaps are a dime a dozen at junkyard. You can get practice taking apart too if you go there. Nobody ever pulls evaps... but if part number is no more than you can get it there.
Have a hard time believing they don't make the part anymore, possibly just changed to a different part number. However, if you need you can call ABC auto salvage in Tucson. They have parts pullers & I think they mail parts out too. I pull my stuff there. They easily have four of them in their lot alone.
Do you have rear heat as well as AC?
Matthew Jeschke
Sahuarita, Arizona
You definitely don't have to cut ANYTHING to fix. I see some guys possibly cut for front evap but isn't necessary. If somebody is cutting up stuff in tutorial then it's a bad tutorial I'd not do what they say.
Can pull front in a few hours. Rear is probably 30 minutes, much easier. Pull plastic trim panels off and air handler is right there on rear passenger side. It's been a while since I did it but has some metal clips (screws too?) and top comes off air handler. You have access to evap then).
S33k3r
Dallas, Texas
Mine is behind the dash, in the front. The "proper" procedure" is to pull the entire dash. The hack "procedure" is to cut through the glove box brace, then the plastic enclosure for the core, pull out the core, put in the new one, reseal the box, and reinstall the glove box (minus the part of the brace you cut out).
Matthew Jeschke
Sahuarita, Arizona
I'm actually curious where exactly leak turns up on the rear evap. The inlet, outlet, in the heat exchanger portion, on the fittings?
I have a pesky leak in my AC system I cannot locate and maybe it's in same place... Mine is fairly slow though. Leaks out over course of couple months.
Yeah I wouldn't follow that tutorial where he cuts the dash. I watched that one. It's not that hard to pull the dash. You have the trim panels on outside which all pop (and screw off). Then some controls in middle of dash, and fuse panels on both ends. Remove the control panels / head units, the fuse blocks pop out (they're just clipped in).
Afterwards, get a steering wheel puller (optional) and pull the wheel. Takes all of maybe 5 minutes if even. Now your dash / core support can be pulled out of the way. You have some more computers and a metal bracket on both sides of cabin. Unplug the computers, unscrew the metal brackets. This reveals the main support, a big metal bar. I am not 100% sure if you need to remove that, I don't recall. However, it's just a couple bolts and fastened to the A pilar. This all takes a couple hours. If you've never done it before then it's daunting. There's a method to the madness though. Screws for plastic are all same, screws for pillars are all the same, etc. Once you see that, it's hard to mess up. The hardest part will actually be getting the screws / bolts undone from front of firewall which support the air handler. I'm not 100% sure if you can leave those in and take top of air handler? I think you can... If so, this isn't too bad a job to do. If you do remove the air handler, swap it out with an earlier 2001 model... The newer ones don't have cabin air filters.
There maybe a way that's easier yet to pull dash leaving it assembled. I think I saw somebody do that once. If you're paying to have somebody do it though, I'd want them to do it right.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I just bought a set of their gauges and I am having issues with the adaptor I bought and what seems to be a resealable can of refrigerant. Works like crap. Not sure if I got the wrong adaptor or what. The gauge kit is nice, got it on clearance.
89Suburban
SE PA
That's the one I bought above, even then we've had several dud cans and were able to return them for exchange at O'Reilly's.
USCG
Heard that the rear units are problematic. Have an '02 Suburban with rear a/c and lot of trouble tracing down the leak. Not sure if it actually was the rear.
Don't use any stop leak - it gums up everthing. Had to get new compressor, dryer & condenser and orifice tube, seals, o-rings, etc. Amazon sells a rear block-off adapter for $20 which works well. I now have a good working front A/C. Don't over look the schraeder valves or the other sensors, as well as the PAG oil & dye.
I went all new parts, because of the stop leak, and to avoid going into this issue 2 or 3x.
Don't have rear a/c, but at this point front air is better than no air (Houston, TX).
S33k3r
Dallas, Texas
Amen to that one! I live in Dallas and the heat has been oppressive. I can only imagine how much worse it has to be in the land of heat and humidity.
Spoolin
Memphis, TN
I have both cores leaking and am looking at $2K plus to replace both. Am going to do the heater core while they’re in there so won’t have to go back in there for the rest of the trucks life (fingers crossed). It’s an 06 with 200k miles.
The dye is all over my front vents and in the rear, it’s is all over the slits in the rear panel on the right. Go out at night with a UV light and looks like predator got killed in there.
If you are savvy with taking photos, consider doing a tutorial of sorts.
Matthew Jeschke
Sahuarita, Arizona
The rear is REALLY easy to get at. Might be worth considering doing it yourself. I redid my rear... I've also tore apart the front. The front is more involved. Many people cut the dash to do it. I'd not do that. I'd do it right and take out the dash itself. That said the front isn't impossible just a lot more fasteners and stuff to get out of the way. I've taken apart a few of these dashes now... go to the junk yard and take one apart for practice then take yours apart. That said it maybe worth it even at $1200 to have a shop do the front. Especially if they'll warranty / stand behind the work.
Spoolin
Memphis, TN
Dye in Front vents and the rear panel as well as carpet at the bottom of the panel.
1948Buickroadie
