What's a good year? Or one to avoid?
tahoefirst
I'm considering buying a used Tahoe, from years 2000-2006.
Is there a particular year that is better than the others?
What about transmission, how long can I expect it to last, any warning symptoms to look out for?
What's considered too high milage?
I know about some issues that seem common, like fuel pump.
I also see some cheap ones for sale with cylinder misfire, are there any common issue for misfires on these models, or just a whole host of possible reasons?
Scottydoggs
NJ
when your looking at any car/truck. check all its fluids, the tranny, pull the stick out, you want the color to be red/pink. if its dark brown or black. just let it go. its gonna need a tranny soon if not asap. unless its a really nice truck and you can knock the price down a lot over that.
misfire can be a lot of things, from clogged cats, bad coils, needing a tune up real bad, to a bad injector. if you have a code scanner bring it and scan for codes.
you can pretty much expect most of the belt driven accessories on the engine to be wearing out by 100,000 miles.
MassHoe04
Western MA
A lot of people know how to erase active codes, but don't don't have a scanner that can go into the stored codes to delete or they don't know clearing a code won't necessarily wipe out everything in memory.
You may show up and see no CEL, because the seller cleared it. If you can dig in deeper with your scanner, you can see what the code history is and even how many miles since cleared. A decent scan tool is great to show up with! Tech 2 scan tool, even better!
You will be equipped and ready to see if someone is trying to pull a fast one just to make a quick sale or cover-up bigger issues.
If someone is willing to cover something up, they don't deserve your money.
Alex_M
00-02 is what I personally prefer. They're electronically a bit simpler. Engine, transmission, axles, brakes are the same 00-06.
If electric fans are a concern, that's an easy retrofit. I put electric fans on every vehicle I own to replace the mechanical fans.
All that said, 02-06 are still great trucks and I would (and have) owned them.
The biggest thing is finding one that's been well cared for. If you can get service history with it that's a major bonus. In those year models, the transmissions are all 4l60e's. I've seen them go out at 100k miles, I've seen them last 250k+ miles. I replaced the '60e in my Tahoe at 280k miles. It all depends on how the truck was driven and cared for. Mine was daily driven the first 17 years of it's life, mostly highway miles, by the guy that bought it new. Around 200k is fairly typical if it's not been abused but it has been used to tow some.
Engines can last a long time. Long long time. There are some running around with 400k+ miles on them. My personal just clicked over 300k and still makes 65psi of oil pressure running down the road. Very happy motor long as I let it warm up for a minute or so.
If you can find one that has hydrostatic brakes, that is a killer system. My old Z71 Tahoe had them and my current 2500 work truck has them. I intend to retrofit my current Tahoe as well.
There's not a lot of bad in these trucks. The biggest thing is finding one without much rust. You may decide to find one that the trans is already going out in at a really good price and have a *reputable* transmission shop rebuild one for you, if you have one around. I'd be willing to travel to find a really good trans shop. Ask local race shops where they recommend rebuilding 4l60e's if you decide to go that route. Alternatively you can order a trans from a big name rebuilder (Gearstar for example) and have a regular garage install it.
A big indicator of trans health is the color of the trans fluid. If it's brown it's been hot. If it's bright bright red it's recently changed. If it's mostly red it's probably old but the trans has probably not been abused. Wipe it on a white paper towel off the dipstick to look at it. If it has fresh new trans fluid in it and it still drives well, that does at least tell you that there's still material on all the clutches. If a '60e is badly worn and you replace the trans fluid then it will sometimes never move again. The old clutch material suspended in the fluid is sometimes all that's keeping a badly worn trans moving.
That's about all I've got. Ask if you've got questions. The trans is the only real weak point of these year models, but the '60e is still a good trans. I've built several of them and I use them well above their original intent, so don't be afraid of them. Just look for the warning signs. Most of these trucks are high mileage now.
Teamiez
I vote for the 00-02 models, as stated above less electrical stuff to go wrong, I believe in 2003 they changed to a whole new harness and what not? I could be wrong. But in my eyes 2003-2006 is where they started to cheap out on little things such as floor & glove box lights and also changed the interior style up a bit. These SUVS are getting old so I am sure most will have there own problems that can be addressed if bought at the right price. I wouldn’t mind doing some work if the body and frame was rust free, Atleast where I live in Western NY aka salt heaven.
MassHoe04
Western MA
I am still learning, so I'll ask...
You mentioned your Z71 had hydroboost brakes. Did all Z71 have hydroboost system or just some?
fishcop076
