4l80e swap - transfer case question
jeffg
I am picking up my 4l80e transmission today and I noticed that it still has the HD transfer case bolted to it. The seller wants an extra $300 for the HD transfer case. Is it worth it to keep the HD transfercase, or should I use the original tahoe transfer case and swap the input shaft? The tahoe has Autotrac, but I dont know if the 2500HD that the transfer case is from did or not.
If I use the HD transfer case, can I just swap the motors/electroncs and make it plug and play?
@randeez
Randy, would it be easier to use the donor or swap parts into the existing one?
randeez
south florida
swapping the input would prob be a the easiest to keep everything else working, not sure if a 3/4ton came with an equivalent autotrac. and may need driveshaft shortened
J
jeffg
Look like the new TCase is an NP263HD. Looks like its probably a no go. I guess I will just order a new input shaft and throw this one back on marketplace.
rockola1971
Indiana (formerly IL)
While you are changing the 246 input shaft, you might want to address the pump rub problem with plate fix and dont be surprised that the chain needs replaced too. Me personally...If im opening up its getting new seals, bearings and likely atleast a chain along with the pump rub fix plate.
J
jeffg
Thanks, I will keep that mind.
J
jeffg
Is there a good shop that sells a conversion kit for the 246? input shaft, bearings, seals, etc? It looks like Merchant has some good parts for the pump rub problem.
rockola1971
Dont forget to inspect your rear case halve for the infamous pump rub hole. If it has already started, junk the rear case halve and get a new rear case halve or maybe a salvage one. If your vehicle has the Auto 4wd option then you will need to buy 2qts of the blue fluid (which is NOT pure tranny fluid).
You will need a pair of extended reach internal/external snapring pliers to remove the various snaprings. Bearing and seal drivers are a big help but can be replaced with ingenuity.
Stick your bearings in the freezer the night before the big day of reassembly.
J
jeffg
Wow! tons of help. Thank you. I really didnt think I was going to have do all of this 4l80e stuff, but my tuner said I would probably regret not doing it now while everything is apart. He doesnt think my mildly built 4l60 would survive for long.
rockola1971
4L60E Survive behind what?
J
jeffg
The new engine package is:
LQ9 with forged internals 10:1 CR
BTR cam, valve springs, SS valves
Ported and Polished heads
Manguson TVS2300 @ 6 or 8 psi.
efans, electric water pump, some other odds and ends.
rockola1971
Yeah I think it would be wise to stick a 4L80E behind all that. A mildly built 4L60E aint gonna last a fruitful life behind that LQ9 with goodies.
Sam Harris
Ahem.. pardon me, but pics or STFU.
That is all.
Erickk120
I'm jealous! If you want to, you can upgrade the stock 3-4 pinion planet from the 246 to a 6 pinion planet, just for the hell of it, can be found under $100
As far as the pump anything even the spacer/shim design will do it, but I'm biased towards the merchant fix, as its fused as an assembly with the pump.
Sam Harris
Is there a build section somewhere? I wouldnt mind posting progress pics.
I’m supposed to be doing one of these myself… so I suppose I can’t really b i t c h at you.. however, I’m pretty tied up at the moment.. :)
Charlie21ny
