Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I used it to get on the roof so i could power up the swamp cooler.
pulled under the eave opened the sunroof, popped thru it, and stepped up onto the roof. beat the hell out of a rickety ladder.
highrollin113
Undercover
Edmonton, Alberta, Canada
well i fortunatly had bought new wires when i did mine this time, but i have run into this problem before and ruined wires, but a trick i was told and i have not tested it, is to take lubricant in a needle, you can get at drugstore, and inject from the top of boot, like i said do not know if it works but i think it could, if you try let me know
1LowHoe
just lowered the back end of the hoe to were theres just enough room for my index finger haha realllly low now. =] anddd got 2 RF P2 15s cant wait to put em in
thehoe92
fo sho
The916
rolled the fenders more
sanded down my bow tie more and put a couple more coats of purple on and installed it
BOSS
The People's A D M I N
Dallas
Today I screwed in my Lloyds floor mats fasteners to the new carpet
B
Travieso
Boooooooost !
Los Skandeles, CA
light coats
the bow tie has a curve to it so if you put to much on it may look good for a couple seconds until it settles down around the edges
i was told i had to take the top layer off which was some plastic then sand down the chrome part and primer and paint that ?
Light coats like mentioned and use some etching primer first to get you a good base.
---------- Post added at 11:54 AM ---------- Previous post was at 11:53 AM ----------
your saying just paint over the original bow tie like dont even prep it or nothing or even sand it down, just throw some paint on it ? what type of paint should i use i want to color match it white..
Oklahoma
Take some wetsand paper like 800 will work well. Get after it. Wash it real well. Rub some alcohol on it. Then use some etching primer. Wet sand the primer with 1200 or 2000 to get smooth. Clean really good again. Spray some white on there. Light coats like mentioned before. You can sand the color if you want with 2000, but sand lightly. Then get some clear on there use lots of clear because it will be on your grill, so its gonna eat some rocks.
First time i did mine.
What i did sunday.
obo
allover NWA
Yesterday I took off the old tint the previous owner installed. The front windows were purple. No longer tho! very easy too
Buford bubba
