Exhaust question for 2500 owners
A buddy just bought an '02 Avalanche 2500 (8.1). The entire exhaust is missing from the after the cats so I'm trying to help him source the parts to rebuild it. We're looking at aftermarket stock replacement mufflers and tubing, but not sure if they're for the 2500 or if there's any difference between that and the ones for the 1500s. Can anyone help with muffler dimensions, pipe diameters, placement of pipes (close together, spread apart, staggered, etc.)?
This is what I have on my 2004 Silverado 2500LD:
MBRP Exhaust
Thanks. But, I should've been more clear. He's not looking for any performance stuff. Just stock replacement and the aftermarket offerings are cheaper than OEM. We're assuming the 6.0 stuff (layout and pipe diameter) is the same as the 8.1, but trying to find something definitive.
I suggested to just get a muffler or two and a universal pipe kit or two and get to welding...
bigdog9191999
sw michigan
I can slide under my suburban in a couple days if needed.
Seems like it is 3 1/2" it comes two pipes into the muffler, and two out then a"y" into one for the tailpipe.
Best I can recall, this is the same as most any (or all?) GMT800s. I wonder if it's just standard Escalade/Denali exhaust.
bigdog9191999
sw michigan
I don't believe so. The configuration is the same but I am pretty sure the size of the pipe is larger on the 8.1. I can also try to confirm that later also.
easiest way to verify that is compare part numbers of exhaust parts for each engine/chassis configuration on rockauto or even autozone.
RA was the first we checked. Besides a Walker/DynoMax system, all they have is OEM replacement mufflers from AP. They showed dual 3" inlets and a single 3.5" outlet. The "local" parts stores don't document anything for the 8.1.
I think he ordered a muffler that was supposed to be an OEM replacement and it had dual inlets and outlets. He doesn't care so much about the configuration. He just doesn't wanna put a system designed for a 6.0 on his 8.1 if it's not the same. We can't figure out why someone would remove the entire system from after the cats unless they wanted the large size for a performance build. At least they left the cats!
He's in Kansas so I'm helping remotely. He's stays really busy being self-employed, so updates from him are slow.
bigdog9191999
sw michigan
This is what the oem muffler looks like on both ( this one specifically is our Denali. A tape measure or calipers would tell the size of the stock pipe easy enough, ( pretty sure the Denali was 3" and the 8.1 3 1/2., Would be minimum of this Evening that I could find out. )
bigdog9191999
sw michigan
This is what is on the Denali now, my avalanche had an actual dual in muffler , but the exit looked basically the same as hers.
rockola1971
Indiana (formerly IL)
They sure dont show anything but GMpartsdirect.com shows 6.0L and 8.1L same exhaust part numbers for front pipe and catalytic converter. It appears there was a 1st and 2nd design.
View attachment 368141View attachment 368142
That is what came in my 8.1 Burb. The inlets are necked down to under 3”OD. The exits are 3” OD. The tailpipe exit is 3” OD as well.
The muffler is 25” long X 12” wide.
Excellent! This is what I needed to see. Now we know what to look for since we can't trust what's listed in online specs.
Thanks, guys!
And that's all of what he still has. Something else to note is that if the exhaust forward of the muffler will support an 8.1, then it's plenty sufficient for even a warmed-over 6.0.
I just thought of something- I wonder if there are California emissions and non-CA emissions versions. Between this link and the pics the others posted, I believe we can get the correct parts.
Thank you!
If your buddy wasn’t in Kansas I’d say come get this stuff. My Suburban is getting swapped to a Duramax = won’t need this stuff.
Bad ass! You doing the work?
Curious, though- where are you located?
Bwaldron
