Amaster
Is there a way to bypass the stupid transmission governor of 95. I hate that thing while passing in are stretch of 80 that are 80mph
lots of options out there, you can buy a canned tune online, from a shop, blackbear and othersIs there a way to bypass the stupid transmission governor of 95. I hate that thing while passing in are stretch of 80 that are 80mph
2011 gmc yukon I think it's just a this gen thing already have a range to disable the afm but God never realized that would be so annoying.What year model? My 22 Z71 will go more than 95.
D.
Transmission governor?Is there a way to bypass the stupid transmission governor of 95. I hate that thing while passing in are stretch of 80 that are 80mph
Yeah when it gets to a certain speed it will shift down not allowing you go above that speed which is 95 or 94 govnerd idk how to spell it.Transmission governor?
Will look into at some pointMine tops out at about 134 now....drag/hp limited.
Its not really a limiter per say. The deal is that there are no more instructions in the PCM for spark, fuel trims, etc. above a certain speed. For instance, why would you want a stock tahoe to be able to go 150mph (Not on a drag strip)? Thats just begging to die going that fast in a vehicle that is not designed to be a race car and WILL NOT handle like one. There are no instructions for a K Chassis (Pickup or SUV) in the PCM that will allow 1xx MPH. They had to stop somewhere in the programming.Its a speed limiter in the PCM. You have to change the tune.
There is NO governor in a 4L60E tranny either. It will go as fast as the amount of engine you put in front of it until the tranny gets more than its rated for or can handle and grenade.
There are two different speed limiters from the factory:
VVJ: Calibration Speedometer (180 KPH/112 MPH)
VVK: Calibration Speedometer (200 KPH/124 MPH)
My 99 GMC Sierra 3door OBS 5.7L Vin R would shut down at 99MPH. And I often ran it to that on an airport runway when called out in the middle of the night to the airport for equipment repair.USA trucks/SUVs were mostly limited at 95. My 93 Tahoe/blazer, 99 Tahioe, 2013 Tahoe LTZ and my 2000 F350 DRW 7.3 were all limited at 95 and all mine got removed. Of all of them the LTZ with the active suspension rides as stiff as my Vette at those speeds and handles pretty good, but stopping a 5500 lb brick at those speeds is different. The "instructions" above a certain speed are still there, the limiter just says you cant go faster. At any time I can just change the mph number in EFI Live on my tune and it wont go higher than that.
Well that is interesting, guess I learned something. Maybe no "speed calibration" RPO means limiter at 99? The Vehicle Information Kit PDF sadly does not say detail the speed limiters.Well, my two GMT900 trucks are 'none of the above.' From the factory, both topped out at 99.
