Tow Mirrors That Don't Shake.
2007YukonXL
I have a 2007 GMC Yukon and I bought some tow mirrors on Amazon and both sides just shake like crazy when driving down Highway. They're not completely useless but pretty close.
I rode in a friends new GMC truck and the OEM mirrors were rock-solid. So I know solid mirrors are possible.
Does anybody have any recommendation for good tow mirrors?
I am referring to the kind that are electrically adjusted, heated, and have the turn signal function (on the outside) and hopefully even back up lights. I find that the turn single LEDs on the mirror glass are kind of annoying when trying to change lanes at night
THANKS
THANKS
Factory mirrors. Someone recently posted that the ones from 1A Auto did not shake or quit shaking after some mod, don't remember. I am getting them but they will be factory ones, 19202235.
2007YukonXL
Thanks.
Has anyone happen to have done this modification and can lead me to a good make/model of tow mirror?
Anyone...anyone...Bueler???
THANKS
Trailblazzin
Lancaster PA
Thanks.
THANKS
I just got the boost mirrors, haven’t put them on yet as I’m waiting for the caps to be color matched. I’ll let you know how they work out.
Geotrash
Dave
Richmond, VA
I have these and they work fine for hauling our camper. It would be nice to have more surface area but I find them adequate for the purpose.
2007YukonXL
I have tried tow mirrors from Amazon and eBay and it seems that they are the same manufacturer.
The bottom manually adjusted mirror is rock solid however the top electrically motored mirror shakes really bad.
Has anyone found a brand that will not shake?
Any help would be greatly appreciated!!!
jsoltren
@swathdiver did you ever end up getting 19202235 mirrors installed in your truck? Did they just plug right in or did you have to swap some connections around? Considering these for my 2013 GMC Yukon XL 2500 SLT, it's got RPO code DL3 on the mirrors.
I have the same mirrors @Geotrash recommended. They're fine, but they interfere with power fold, the outsides shake a bunch, and I need to re-adjust them every time I close a door. Glad to have them, better than nothing, a cheap and easy fix, but GM tow mirrors would be ideal.
@swathdiver did you ever end up getting 19202235 mirrors installed in your truck? Did they just plug right in or did you have to swap some connections around? Considering these for my 2013 GMX Yukon XL 2500 SLT, it's got RPO code DL3 on the mirrors.
Not yet, I'll get them after the rear axle project. Checked the other day, prices have gone up over a hundred bucks. Still getting them when ready.
Larryjb
I got McKesh mirrors. I don't get any shake. It also allows me to keep the stock mirrors aligned to see beside my truck, and the McKesh mirrors allow me to see beside and behind the trailer. This arrangement gives me more mirror area and I find it quite useful.
Stock towing mirrors would allow you to not have to install them each time, but these MeKesh, once aligned, don't take long.
scottd
