Service suspension system
ukrkoz
Auburn WA
Hi all
I started having Service suspension system on and off on MFD.
2007 Tahoe LT, 150 000 miles, air ride equipped, electronic front shocks.
I can't find any error codes and I do have CAN BUS scanner.
Compressor kicks in every start up, as it should.
Ride is bumpy.
Spraying soapy water onto rear shocks didn't reveal any leaks.
There is water in air lines, I saw that. Rusty water.
Bellows are intact.
It is not consistent message, but most of the times at start up.
Suggestions? Thank you
U
ukrkoz
Auburn WA
Roger that. Makes sense. Any best priced capable scanner recommendation?
U
ukrkoz
Auburn WA
OK, so I got C0585, which is rear left actuator circuit malfunction code.
What exactly is that? I, so far, found a spread from bad strut(?) to bad compressor. Compressor starts as it should.
What am I looking at?
Thank you
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
See post #135
U
ukrkoz
Auburn WA
Sooo, it's either bad connector or bad electronics inside the shock? To be honest, I had truck up on the lift and shock extended all the way down, ripping off connector. It really surprised me, why connector wire is so short? I'll check on it. That might be the ticket. Otherwise, shock, though aftermarket, is basically brand new. I, also, have another one, still wrapped in paper.
George B
¯\_(ツ)_/¯
“Ripping off connector”?
U
ukrkoz
Auburn WA
Yes. Shock extended all the way down, bellow had no air in it and plug from compressor came out of the shock connector, as the result. That wire for it is awfully short, it barely reached the plug.
George B
¯\_(ツ)_/¯
That electrical plug should be on the top of the shock and not with the suspension. I know on the Arnott shocks if there is no air in the bladders they will slide down the shaft and pull on the air line.
U
ukrkoz
Auburn WA
It is on the top. I'll shoot picture tomorrow, it's 8 pm here. Plug is connected to wire that goes into the compressor housing area and is hidden in the insulated conduit and it BARELY reaches the connector. I tried to pull wires out more, but not really. Maybe I should release those 2 wires somehow, as they are awfully having no slack to accommodate suspension movements. Right side is fine.
ivin74
05 NBS Nali
Htown, Texas
Thank you
How old are the shocks? If the electrical connector to the shock is on correctly the problem might be the shock and it needs to be replaced.
91RS
GA
Junk Arnott crap. Replace it with OEM and you’ll be good. If you found water in the air lines you need to replace the compressor as well.
U
ukrkoz
Auburn WA
Yep, water lines spit out water.
Oh well, at 151 000 miles, that comp served well.
I'll get it replaced, been pondering that for some time.
ivin74
05 NBS Nali
Htown, Texas
You need
Best to do the compressor and the shocks at the same time. Buy OEM shocks, the Arnott compressors are good. I'm running an Arnott compressor on my suv.
If you are using aftermarket shocks they may not be sending the correct signal to the BCM and that's why you are getting the code. Chances are that's causing the ride to be bumpy.
To keep the ride from being bumpy disconnect the electrical connector and the shock is going to act like a normal shock.
U
ukrkoz
Auburn WA
Yes, knowing GM, if it senses a problem anywhere, it shuts down that system. I know.
U
ukrkoz
Auburn WA
OK, so it's fixed.
Was, pretty much as usual, KISS thing.
That infamous driver side shock plug came off again.
I'll zip tie it in place. Tomorrow. I'm beat, I worked 5 hrs on buddies car.
AdrienR
