Max trailering package question
Buffalown
I found an available 22 Tahoe that has everything I wanted on the order I have placed except for the max trailering package. My question is do you guys think it would be worth waiting just for the max trailering? I guess my main concern is not having the extra camera views and hitch guidance which would be really nice. I also should note that the Tahoe I found online is a 6 hour drive from where I live so not sure if I should just sit tight and wait for my order to be accepted and built or drive down this weekend and pick up the available Tahoe minus max trailering.
Sofa6A
My order is delayed because of the MTP constraint. It’s worth it for me for the additional features. And, I’m not in a rush so I can wait.
Reddevil96
Chandler, AZ
your call, but if your not going to be trailing much or at all, then probably not necessary. not sure on a tahoe, but my 21 yukon xl denali still have external trans cooler and engine oil cooler, and I will not be towing, so I am not too concerned, down the road you could swap radiator and cooling fans to the max cooling setup.
StephenPT
St. Helens, OR
There's aftermarket solutions for the trailer brake controller, camera views, tire monitoring, etc. but they won't be as integrated/seamless as the OEM design. If trailering is a common thing for you, then I would just wait. There's allocations available for MTP, so it's only a matter of time before your order gets picked up.
Get what you want as long as you're able to wait and don't have to compromise.
Buffalown
Buffalown
Thanks for the input everyone I think im going to be patient (as hard as that is) and wait for my order to get picked up. My 2007 trailblazer that the Tahoe will be replacing is still going strong so no immediate need to jump on this one for us. Thanks again to everyone who replied.
It also makes the decision easier now that the dealer sent over the price quote which included a $3k “market adjustment” which wasn’t listed on their website. While it’s *only* 3k it just rubs me the wrong way
Yeah, that would make me look elsewhere if it was not legit and industry wide.
Sofa6A
If my dealer adds a mark-up to my order, I’m walking away. Toyota Sequoia will be ready by then and no DFM time bomb waiting to go off.
NYisles1
If you think its a DFM time bomb why would you buy it at all? The current outdated Sequoia is selling above list in my area so if the market is still tight when the new one gets here I would imagine it will as well.
NIevo
Lewiston, ID
Doesn't it also have different rear end ratio's? I know the previous year Max Trailering packages did.
Sofa6A
Good question. I didn’t realize how widespread the problem is until after I placed my order and started reading about it on the forums. It’s borderline negligent that GM knows about the problem and hasn’t done anything proactive about it until the recent class action lawsuit.
How about you? Do you think about your engine grenading from a failed lifter or bent pushrod?
And I won’t be buying from any dealer for any brand if there is a market adjustment. Costs me $0 to wait.
NYisles1
The lifter problems are really two separate issues. I have no doubts about a higher than average failure rate for the engines built during the time period GM identified and blamed on a supplier. For everything built outside of that time period -- people blame DFM/AFM for a high failure rate -- but i havent seen anything to quantify that rate. I personally doubt its anything over a fraction of a percent. Maybe its higher than the industry average -- or non DFM/AFM motors - but that could still mean a low overall failure rate. And remember GM builds hundreds of thousands of these motors each year - most owners get through trouble free.
I love this forum and learn alot on here. But it can taint your ownership experience. Bad experiences are WAY over-represented (just like on any other forum). So to answer your question, sure I think about the lifters failing, my air suspension collapsing, the automatic assist steps binding, the sunroof jamming, the overhead console blowing out and on and on. I still think the overwhelming odds are non of the that stuff happens.
You mentioned jumping to a Sequoia and sure maybe Toyota does a better job with initial quality -- but the new Sequoia will have a all new twin turbocharged engine with an electric motor, all new air suspension, and lots of onew tech. I wouldnt be surprised if there are teething issues there too.
StephenPT
St. Helens, OR
If the 2022 Tundra forums are any indication, it could be a rocky start for the 2023 Sequoia. Out of the gate, the '22 Tundra has a major issue with turbo wastegate actuators.
H1Chester
The Yoda also doesn't seem as comfortable. Bunch of good TFL YouTube videos on it. I noticed the 3rd row is not great, second row seat don't slide. Strange 3rd row sliding from trunk and cargo setup... Turbos do great things, but over time not sure. On a diesel yes, gasser, ehh...
Polo08816
What size is the rear differential on these 2021+ vehicles?
Geotrash
Dave
Richmond, VA
Got it.
I curious whether it was a 8.6, 8.8 or 9.75" diff.
None of the above. It's an independent rear suspension so it uses a different differential than past generations or the pickups. That said, I note that the 5.3 uses a different GM part number for the rear diff than the 6.2 and 3.0 do.
BadDaddy2003
