Disappointed in ride quality?
Ron McKuin
I have a 2021 Tahoe High Country with 6.2 engine. I just returned from the dealer where I had complained about the ride and cabin noise level.
I have told them that it rides like it has 100 psi in tires! Make bumping and rumbling noise on road? It is very agrivating. They acknowledged the noise and said they checked it over. Found nothing!? Returned it to me saying it was normal?? Blamed the noise and bumpy ride on the operation of the 6.2 engine??
Anyone else experienced this issue? Found a solution? What can I do next to resolve this issue.
Thanks in advance for any advice.
NYisles1
Do you have the air suspension on your HC? I don't totally love the ride on my At4 6.2 w/air - it can be a little harsh over bumps. I held out for the MRC + Air combo thinking that would give the best ride. Many of the reviews i read raved about it 'floating down the road' and i certainly can't agree with that after a few months of ownership. The 6.2l weighs a couple hundred pounds more than the 5.3l IIRC - so the 5.3l front end may feel a little lighter but I don't know why the dealer would connect ride noise to your 6.2l. There shouldnt be any rumbling .... there is a bulletin about noise coming from the wheel liners on '21's. I'll try to find and post that..
Actually Like2detail had posted it recently in another thread : Link
tabraha
S.C.
My MRC+Air rides as smooth as my LX570 and my Model S with adaptive air suspension.
If you don't have air ride and there is clunking they need to run through to make sure everything is tightened up from the factory. When I took delivery of my ZL1 I had to go back at 100 miles as the sway bar was flopping around up front. Just was never tightened up when it was built evidently. Fortunately I'd worn out bushings on swaybars at the track before and recognized the noise LOL.
Regardless, the dealer blaming the engine for harsh ride and bumping noises is not correct. I don't care what engine it is. I also agree the wheel liners could be flopping too. Hadn't seen that thread. I think the mud caked on my liners keeps them from moving! :rotflmao:
Quark
Atomic Nuclei
I'm guessing these don't have selectable ride settings.
You might try to test drive another HC w/air ride if you can find one otherwise you could take it to another dealer.
What tire came on it, some ride very hard. How many lbs. pressure?
Saltydog
I have an SLT with 4WD, no Air ride or Magnetic Ride control.
I am not impressed with the in-city ride quality, very jittery and you feel just about every little pebble in the road.
Now the highway ride quality is very good and almost floaty.
Once I changed out the tires, I seen a small improvement in ride quality. My guess is that the shock tuning is to blame, but I am no engineer.
Our previous SUV was 2017 Ford Explorer and the ride quality was way better. So I am bit disappointed, heck my 2020 Ram truck has a better ride quality.
All that said, the wife is over the moon for our Yukon and has never complained, its her DD so I just figured it was me being a bit to picky.;)
R
Ron McKuin
Do not have air ride but the magnetic control suspension. Thanks for info.
R
Ron McKuin
Came with Bridgestone Alenza 275-50 R22. I run 34 psi in the tires. I have tried more and less air with no difference? Thanks
R
Ron McKuin
I do have 3-4 ride settings. Normal, off road, tow haul and maybe another? Thanks
Koepp2637
Having a previous and current generation Denali/AT4. I noticed difference with the vehicles riding on 22" vs 20", so tire size and brand does make a difference.
Eusibius2
Chicago burbs
Wow - love the fact that the fix is "use duck tape - obtained locally". Does my dad work there??? :happy175:
Blueinterceptor
On the previous gen. I had a problem with one of the mag shocks. Push on all for corners with truck off. If one is really stiff there may be your issue. Mine rode like a rock when I’d run over the expansion joints
NYisles1
The other one is Sport. None of those drive mode settings change the shocks or air springs. So there is no way to select a softer or firmer ride, although it seems like there should be.
R32driver
Could be the tires and 22's. I've never been a fan of the larger wheels and less sidewall on the tires. 20" rims and 60 series tires ride fantastic on our SLT, no air or magnaride. The ride quality is fantastic IMO and there is very little road noise.
cgator67
I've got no complaints with our '22 RST w/ 6.2L and magnetic ride control. Drives super smooth even with the 22" wheels-- really impressed with it. Sounds like there is something not quite right with yours.
jimgeb
I purposely ordered a 2022 Premier rather than the High Country so I could get the 20” wheels. The ride is the best I’ve had in my 3 Tahoes. The tires do make a difference.
Bigkevschopshop
Northside H-Town
6.2 shouldnt be a couple hundred pounds heavier...
Quark
Atomic Nuclei
Exactly why I keep coming back to the Premier it allows the most latitude for getting the right mix of options and still retain the 20" rims.
I hear these trucks need the 22's to fill out the big wheel wells. They are the same tire height.
R
Ron McKuin
Thanks. I am not having much luck getting my local dealership to take an interest in my problem!!
TexasLC
22s with a lower profile side wall will definitely up the “pebble feel factor”.
MRC and Air will help smooth the ride, but if you’re feeling “pebbles” that’s tire sidewall more so.
But that’s just my opinion : )
EMTPete
Northern Virginia
I have a ‘21 Yukon with MRC and air suspension. I recently bought a set of 2021 OEM 20” Yukon wheels to replace the 22” wheels it came with. The ride is definitely smoother, so much so that my wife even noticed the difference. The 20” rims also seem to match the chrome trim on the Denali better than the 22s and I find myself not worrying as much about large pot holes due to having more sidewall on the tires.
jpurdie
