Scottydoggs
NJ
The flashing MIL was a random cylinder misfire code.
Been watching cam bearing videos, I guess my first step is buying a cherry picker.
flashing cel is like two things almost always, you needed a tune up like 6 months ago, or your cats are clogged up.
Walchit
It has been throwing a catalyst code, for like 500 miles. I figured this was related to the low oil pressure, but maybe not.
Scottydoggs
NJ
low oil pressure should not be causing misfires or cat codes.
if its not knocking yet, op is not that low. most gm techs will tell you 6-7 psi at idle is acceptable. as long as it goes up when driving it.
then again, these trucks are known for the o ring going bad on the oil pump pick up tube to pump.
05 Tahoe LT
Walchit
05 Tahoe LT
Already changed the o-ring, my oil pressure has crept down from 20 at idle to 0 the other night, died at the toll booth and was knocking afterwards. So it probably just needs cats and the engine rebuilt really. Eventually I will have replaced everything though I guess
Scottydoggs
NJ
damn that blows. back to that cherry picker plan. around here ive got rental places where i used to rent a hoist before buying one. used it a couple times and now it sits.
blueinkd
05 Tahoe LT
I have noticed my OP @ about 30 at idle and just over 45 psi when rolling. My rig over 260k but the pump and timing set were done before I took ownership of it about 3 years ago
chevync
North Carolina
I'm still around, just haven't been here for awhile. I still have my escalade, bought it 6 years ago with 105k, now she only has 128k. I did buy a set of springs for the rear, supposed to be 2" and ended up being 3". I also added the 2" shock extenders and the shortend level bars, I'll probably just add some 2" spindles this coming spring.
How many hours did you leave the penetrating fluid on it? Might need to do that a few times over a few days.
Not very long. I was hoping to get it done today. I noticed the bung was starting to bend on the collector, so I stopped. I'm gonna try to get it done by a mechanic.
Or just go directly to a muffler shop so when the bung breaks off they can weld a new one on.
Didn't think of that. There's only 1 muffler shop around here and he's an A1 a$$hole. Charged me $200 to weld a muffler on. Can't even imagine how much he'd charge to do an o2--with a possible new bung.
mountie
Probably old Mob ties. ?? Ya gotta put a little ring on your little finger. first. :cool:
Maybe drive a ways to a good shop?
I have to work it around my screwed up work schedule, plus my gf needs it this week. Hopefully I'll be able to figure it out soon. I drove it yesterday and it felt, and sounded terrible. Weird because no cel, but it didn't light for the other side either.
HeavyHoe03
