GeorgeB’s 2013 Suburban LTZ “Fin”
Just out of curiosity. Did they fix the exhaust manifold bolt breaking issue by 2013? Or is mine susceptible to it as well?
No they didn’t fix that at least through the NNBS platform. Not sure after that but it takes a few years for them to break.
George B
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Finally got some snow here and I had a chance to go test out my Cooper tires. They are the Discover AT3 4S in 285/45-R22. We have a nice layer of snow that is packing well. The tires do really well for how wide they are and the traction control does it's job pretty well.
In 2WD
They don't like to get the truck moving but turning and stopping is as expected as long as you know what your doing. Turning off the TC and STABIL made for some pretty sick doughnuts.
In 4WD
The truck drove great. It accelerated, turned and stopped well. In all the tires performed just as expected according to the reviews on Tirerack.
I was used to driving on Goodyear Duratrac tires and these don't perform as well as them but they fit the bill for me. If I wanted any better I would need to run some dedicated winter tires.
George B
George B
¯\_(ツ)_/¯
Since my front axle repair I received one DTC for a slow response from the B1S1 O2 sensor. I have a pair of them on the bench to throw in tomorrow. Tonight I noted a slight exhaust smell so I hooked up the Tech2 to take a look. Nothing looked too off. -3 LTFT on bank 1 and -5 LTFT on bank 2 at idle. My graph of the O2 sensors looks a little lazy.
Gonna swap those sensors out tomorrow and see what happens. 88K on them as of the other day.
@swathdiver
I saw you chased some screwy trims back in 2018. The thread died. Whatever was the conclusion?
They are still screwy. BlackBear said to check my alcohol content and reset it and he was right, it keeps getting off track whether on Ethanol or Gasoline. I changed out one O2 sensor a long while ago and need to do the other now that I'm able. I'm still thinking the culprit to be leaky intake gaskets, every once in a while we put the torque wrench on the bolts and a few of them tighten up.
pwtr02ss
Tennessee
My 02 sensor logs from my tech2. This is in park.
My B1S1 was reading like that. Changed it, all is well. B1S2 was normal though.
Mind you, that sensor had only 2k miles on it since the refresh. They replaced it under warranty.
George B
George B
¯\_(ツ)_/¯
Easy peasy!
That little adapter was worth it for this job.
George B
George B
¯\_(ツ)_/¯
Ordered a negative battery cable from these guys.
Got one made from 33” of 2GA with the ends on it already for 20 bucks. The small ground cable to the frame by the bumper is smashed and corroded so I plan to put an end on the old battery cable and run it from the block to the frame.
That’s not a bad price.
George B
George B
¯\_(ツ)_/¯
My new cable is made and shipping today! Holy smokes!
Now to figure out how old my battery is. My guess is it's at least 4 years old.
I want a replacement but need to decide if I want to go with an Interstate or a unit from Northern Battery. I have had several Northern units over the years and no trouble with any of them.
I’ve had good luck with Interstate. Probably can’t go wrong with either. Have you decided on the type- AGM, etc?
CrackerJack135
