Limited Slip Differential on 2022 Z71
62z71
It looks like Chevy finally offers a LSD on the 22 Z71's, does anyone have any information on this?? That, along with the 6.2 availability, makes it a ton more appealing.
wsteele
It looks to be the same as GMC has been offering in the 2021 AT4 Yukon's. People seem to think it is a big upgrade over the G80 locker when things get gnarly on the trail. Having said that, I have a G80 in my 2007 Yukon and now my 2021 Sierra 1500 AT4 and frankly only have had a few instances (in 14 years) where I think the eLSD might have made a difference over the G80.
Here is a comparison the TFL guys did between the G80 (Trail Boss) and the new eLSD (2021 AT4 Yukon). The eLSD looks pretty sweet.
Thomas Schneider
Yukon, OK
FYI; For 2021, it was just the "Mechanical Limited Slip Differential" RPO code "G86" (new for the independent rear suspension). So it did have a LSD, just not the electronic version, which it looks like they're offering now.
SSGUNNER
Yea my 21 RST has the LSD which is labeled on my sticker as well. Haven’t gotten a chance to use it yet but from the vids I’ve seen on YouTube it seems to work well. That video from TFL was a failed attempt as it was not engaged during the video. There are others that show it working. Granted the ELSD seems to work flawlessly but correct me if I’m wrong in the Z71 it’s only available with an off-road package or is it standard now. Think I saw something you need an off-road package on the Z.
wsteele
Thanks for the correction. Not the first (or probably the last) time those guys got the facts a little off. I will say, the mechanical LSD they had in that Yukon looked pretty good compared to the G80 in the Trail Boss.
wsteele
What was not engaged?
NYisles1
The '21 Yukon had the eLSD available on the At4 and Denali. That is what they tested in that video. Other trims of the Yukon and all Tahoe's/Suburbans could get the mechanical locking diff. For '22 the eLSD is also available in the Tahoe/Suburban.
wsteele
Thanks for the correction of the correction. All fairly academic for me as I have two G80's, which seem to work fine for all the off-road stuff we do.
NYisles1
Same here, the G80 has always worked well for me. Havent had the eLSD in anything slick yet - can't imagine the difference is all that significant unless you're into something pretty rough.
H1Chester
You have to get the OFF ROAD PACKAGE to get the eLSD. I stayed away because I don't necessarily want the air bags going bad later. Other manufacturers have had air bag issues...
Also, if you are not opted with the eLSD, the standard rear end is NOT a locker. Also not the G80.
A couple threads on this, including mine...
X-ray Nerd
