Depo projectors
vatahoelt
NoVa
For the people that have them, how bad is the shaking with the plastic brackets? And what options are there for stiffening them up?
Bailey-Hoe!
Vermont
My shaking is not noticeable during driving, even on crappy VT roads. there is some shake when I hit a frost heave but you do not notice it because your teeth are also rattling.
For peice of mind however, I would like to stiffen mine up. I do not want any rattling to knock off adjustment or look annoying to oncoming traffic. It cheapens it.
On a side note, I have seen so many crappy cars out there with HIDS in non projector housings. It urks me....so glad you got DEPOS.
BB
V
vatahoelt
NoVa
BB
I did just put in my HIDs, but i haven't gotten the projectors yet. :emotions33:
i was just wanting to make sure there wasn't that much shaking. i'm with you and feel the shaking would make them seem cheaper. I think i'm going to pick some up since my birthday was monday. and eventually i'll probably do the retrofit on down the road.
would it be possible to use the factory bracket or do the holes not line up as i've read elsewhere?
Bailey-Hoe!
Vermont
Not really a bolted together type part. I am interested to hear what others say. Check my reccent post..you can see my lights HID + DEPO + FOGS and Clear bumper lights.
V
vatahoelt
NoVa
Not really a bolted together type part. I am interested to hear what others say. Check my reccent post..you can my lights HID + DEPO + FOGS and Clear bumper lights.
i read where a few used half of a ping pong ball to stiffen up the brackets. not sure i like that idea.
Tahoeatl
Duluth,Ga
BB
i ordered some depo's for my hoe... but i was thinking...
whats the big deal with projectors?
reason i mention it is i just bought a G35 infinity that has some bright ass hid's (STOCK) in it but the housing isnt a projector...
looks great, i havent yet had anyone flash me in the tahoe or infinity.
though i will say with the tahoe behind me with the g35 being rather low to the ground... my lights in the tahoe are bright as hell but not blinding, just irritating to see in the rearview or side mirrors seeing that the truck sits up so much higher
Bailey-Hoe!
Vermont
I think it has to do with scattering light. Projectors prevent ALL THAT light from going all over...in theory.
I just like the looks. I hate that fogged over opaque stock garbage.
BB
kses123
kses123
Raleigh, NC
I am lazy and did ping pongs lol. Sounds silly, but it worked. You could change the bracker over from your OEM headlights I believe. They are much stiffer. Or you could stiffen up the bracket where the pin goes in the secure it to the car. That is the part that flexes. Attach a piece of metal to it or something.
MikeTheApeman
The armpit of America - New Joisey
Here's my take:
If you're the kind of person that is **** about their ride, you'll notice the bouncing. It's not severe, but I am insanely crazy when it comes to stuff like that, so I had to do something. Some folks have said when they put their HID's in, the bouncing went away (theoretically from the wiring and such filling the space), but mine didn't. The issue is that the part where the pin goes in is only attached at the top of the assembly. I took an old spacer from a universal flat panel mount I had laying around and glued in between the back of the headlight bowl and the arm that the pin goes through. That stiffened it up much the way a ping pong ball would.
Honestly, it didn't seem like that big of a deal to fix. That's the only negative I have found to the Depo's.
LordGeek
Ohio
might b able to put ur gm stuff on the depo's
You know, that is an excellent idea there.
I have noticed the slight shake in the DEPO's since I installed them, certainly didn't think about removing the old OEM brackets and trying to mount them on the DEPO's instead .. it's raining here today, but will hit that up as soon as it clears.
TnTahoe
TN
where are you all getting the depo projectors from?
V
vatahoelt
NoVa
Post up what you find out. I'm betting the gm bracket won't line up perfectly.
DenaliAK
Colder than you
Alaska
What year is your Infinti? If it's '06 or up, it has projectors.
Some cars do use HID in reflector housings, but they are reflector housings designed specifically for HID's.
Problem with HID's in most reflectors is the reflectors aren't designed to focus that much light, which generally results in massive glare issues.
V
vatahoelt
NoVa
Denali, I posted in your retrofit thread, but do bmws have projectors?
DenaliAK
Colder than you
Alaska
That's a good question. They have weird headlights.
HID lamps are an option, but not standard, and those are adaptive, auto-leveling. Not sure if they use a projector or some other mechanical shield to control the light. I'll look into it more later. Gotta head out the door to get my truck fixed....lol.
Might depend on the year/model as well, so if you have one in particular in mind let me know.
V
vatahoelt
NoVa
I'm getting both headlights assemblies tomorrow, so we'll see what they look like.
Bailey-Hoe!
Vermont
Will someone please post a pic showing their stiffening methods? I am tired of hearing about and not seeing it....and not 100% tracking on your descriptions of ping pong balls and flat screen mounts. Gotta see it to believe it before I take a can of insulating foam to my front end! Hey, that would work!
PS - I am starting a new forum, DEPOprojectors.com where we can talk about lights with out all this truck nonsense! Ha ha
BB
emay
S. Elgin, IL
Well, with a little lubriderm on your ping pong balls, you will likely not need pics to witness stiffness..
Sorry, I had to go there-
Hodmjstone
