What do you find gives you more power?
mdiacont322
Senior Member
do you guys find that you get more power out of your 5.7 when you:
1) run open cats
or
2) run a high performance muffler (ex. flowmaster, magnaflow, etc.)
Im wondering because im thinking about taking my flowmaster off (feels like theres no power) and getting the magnaflow 15701 kit in a few weeks.
Gimme some ideas on what you think
Mike
TigerEyz3
Slow and Steady
TN
Can't address your first one... I live in an emissions testing area.
On the second one, I've run both a Delta Flow 50/SUV muffler and now a Magnaflow catback. In both cases, I had my Thorley headers... I far prefer the performance of the Magnaflow.
young_2010_chris
it helps alot but u need a programmar if u dont like lookin at ur service engine soon lite
Brandon X
Michigan
Just do one and two. Cut the cat off and use the money from scraping it to buy a nice muffler, and you'll even have money left over! It's a win-win situation!
mdiacont322
mdiacont322
Senior Member
ok so i will keep the duals... but what kind of muffler should i slap on for best performance?
young_2010_chris
i cut mine off then i welded pipe ti my axle then slapped 2 40 seris flows and i could tell a big difference i another thing if u havent done is e-fans i thought it helped alot
---------- Post added at 09:02 PM ---------- Previous post was at 09:01 PM ----------
what year is ur hoe
mdiacont322
mdiacont322
Senior Member
i guess it is a good possibility that my cats are going bad... i have sputtering when im cruising between 60 and 80. other than that i dont feel anything though... i have my muffler off and it feels like everything freed up since i had the muffler on.
blueflamed03
Oklahoma
if you need visual, pull the cats off, with a cutting wheel, open the top of it that faces twowards the floor board, beat out all internals, them weld back shut, bolt up. Visually they look OEM stock, inside, they are empty.
AtomicHoe094
Atomichoe094
cleveland, OH
who needs cats anyways!! lol save that shit on the inside tho! or just scrap the oem one out and buy a brand new one (magnaflow high flow ones) and youll only be like 10bucks in the new one
97yukon
baton rouge
i cut mine off just recently...loss of bottom end and a gain from top end. apparantly after i get my truck street tuned at futral tom i should see my bottom gains back as well as keeping what i gained in top. if your concerned with emissions deleting the rear o2 sensors clears that right up. thats what i did and it worked like a charm. just a suggestion
mdiacont322
mdiacont322
Senior Member
how do you delete the rear o2 sensors? and how much bottom end is lost thru hollowing the cats?
97yukon
baton rouge
removing my cats did make me loose low end...i got an upgrade to street tune today at futral and he confirmed it. checked my previous stuff after the basic...ive got it back now and some. i had a hypertech before....definitely go custom tuning.
Bob LaFord
