Tahoe horn
12YukonSLT
I have an ‘04 Tahoe Z71. The horn is not working when the actuator is depressed. Fuse and relay are good, already replaced the contactors and spring inside the steering wheel. What I have noticed is that if I push in VERY ******* the entire steering wheel, it will move in (toward the dash) just around 1/8” or so. When it is bottomed out, so to speak, the horn actuator works perfectly with very little pressure, as normal. Any advice on what the issue is and possible fix(es)?
The horn is actuated by a ground connection behind the airbag. You'll need to find out why the steering wheel isn't fully positioned; there shouldn't be that much movement. The ground connection seems to be too short, not making contact because of too much gap. Might be a steering wheel seating issue or the column not physically intact.
This guy has a possible solution:
12YukonSLT
Not sure why the post put in *****, what it should say is “push in very ******* the entire steering wheel”
oldchev
DIY preferred
Santa Maria, Ca
My 2004 GMC Yukon horn quit. Not a PPV, but ... I watched this video. It worked! Really straight forward.
varminpoolteam
