Afm not working correctly?
BG1988
87 is better then 85 meaning it should be fine it's not a classic car it doesn't deserve it or the engine would've been gone a long time ago amen boom
only use premium bro... 87 will damage the engines overtime regardless of what GM says.... knock sensors are not an ideal substitute for premium gas.. this is also off set by HIGHER MPG i get 20city/ 25 mpg with premium fuel(results may vary per weather and terrain conditions) 87 oct i only get 18/18mpg
Bill 1960
Testing the Limits
E85 is 85% ethanol, not 85 octane.
My opinion manual says 87 and that’s good enough for me. I’m pretty certain Uncle Sam didn’t put high octane in mine when they owned it.
Prior trucks with 5.3 and 6.0 I tuned personally with HPT, and I was not seeing spark knock with factory timing on regular gas.
But I’m always open to learning something new...
BG1988
people all ready compared tear downs with 87 and 91/93oct
the 87 octane had more internal wear and tear... it's also cheaper to run 91+ on the hybrid because of the MPG boost... AFM actually works as GM intended
87 octane is NOT compatible with Active Fuel Engagement
also AFM hyper cycles with 87 octane which equates to more DAMAGE and wear...
AFM works as intended with 91+ octane
with 91 octane you can actually accelerate under AFM
PROOF
0.228 on 91 octane @20mpg City
0.202--0.184 on 91 octane @23-25mpg Highway
0.2316 on 87 octane @ 18/18mpg
no brainier to use 91 octane
this makes 87 octane the loser
Nope why the hell they call it flex fuel then it's just getting regular unleaded if anything I'll remove the disabler if it gives me problems
This is another reason why your AFM doesn't turn on as frequently as it should, you are running low octane fuel that produces less power.
BTW guys mines not a full on hybrid just flex fuel
Well you posted in the hybrid section. If you don’t really care how long your engine lasts or his much it costs to rebuild it, then by all means run regular. I mean, why listen to people who might know what they’re talking about, right?:lol2:
A
Amaster
Laramie wyoming
Well its not like I'm ignoring it.. I'm taking care of it, oil changes everytime it needs coolent changes and I have put a full tank of premium in it no diff plus I would never drive a plug in hybrid just my say
alejo2160
