Finally posting a "build" thread. The progression of my stupidity.
RooTBeeRthe1st
When I bought it June 2018 100,500mi - 6,685 hrs.
First thing I did was add a cabin filter.
Started pulling wires, many many wires.
RooTBeeRthe1st
RooTBeeRthe1st
Started pulling out the partitions and more electronicals.
Got my Mickey Thompson ATZ P3's
RooTBeeRthe1st
RooTBeeRthe1st
Found the wires for the red and blues in the tail lights.
Ghetto fixed some trim with a used reciprocating saw blade.
Removed more useless wires.
Put some Pioneer speakers in the doors.
RooTBeeRthe1st
RooTBeeRthe1st
/Added the boom mat speaker surrounds to the doors.
Took off the sheet-metal Setina door panels and put off the civilian panels.
Changed all of the dome lights to LED's.
Put wireless chargers in the armrest and the center console near the cupholders.
Drivers door panel "handle" broken...9/21 still haven't fixed or replaced.
Threw my old **** 12" sub and amp in the back.
Put a 2" front leveling kit on.
Replaced the front right wheel bearing.
RooTBeeRthe1st
RooTBeeRthe1st
Added my Tekonsha P3 Prodigy brake controller.
Threw on the towing mirrors.
Did an oil Change.
Got snow chains.
Drove onto an (not so) dry lakebed in the middle of the night.
Added LED headlight bulbs.
Took her to Co to visit my Brother for Xmas.
Did desert fun again.
Another oil change and tire rotation.
Took the parent down to a winery.
Back to the desert. Dried up again now though.
RooTBeeRthe1st
RooTBeeRthe1st
Hauled a Bicycle up to Santa Barbara to hang with a friend.
Put in a Pioneer 8500NEX + front and rear cameras.
Added a Optima Yellow Top battery as a secondary.
Took her down some firer roads with a buddy.
Found out the Driver's side engine mount was trashed.
Put some Ray Bestos R3oo rotors and Police pads on it and a new motor mount.
Took her to my buddies in-laws in Havasu.
Launched the boat a few times...parked it among it's family.
Pulled his boat home.
I don't see anything except for your statements. Like has been said, "If there are no pics, it didn't happen".
It's coming, I'm on the clock now. It'll have to wait. :'(
RooTBeeRthe1st
RooTBeeRthe1st
Added a Trucool Trans cooler and thermostat.
Took her to my grandpas in Nor-Cal. Hauled his wave runner to the lake and back.
Then my Cousin's in Nor-Cal.
Picked up my buddy's Volt(same guy with the boat) after he hit debris on the freeway and lost his cooling system.
Took her to the same buddy's for an early morning bike ride to the beach.
RooTBeeRthe1st
RooTBeeRthe1st
Picked up a 6" drop hitch to town my co-workers trailer to the desert with my Quad in it.
Black vinyl rapped the two rear windows.
Took her to the desert for Thanksgiving, it snowed...
Changed the front+rear diff fluids, trans+transfer case fluids.
Another oil change.
Disconnected the Rad trans cooler and ran the external trans cooler by itself.
Air filter.
Trans again.
RooTBeeRthe1st
RooTBeeRthe1st
Pulled the remnants of the Sheriff's antennas and added a cell phone range extender.
Another oil change. and tire rotation.
Changed the cabin air filter.
Replaced all of the window trim and seals.
Another desert trip with the atv.
Another Santa Barbara Trip.
Did the Border Patrol bumper trim.
Put on some Dirt King UCA's.
Swapped to a 160* thermostat.
Another oil change tire rotation.
Did a muffler swap.
Got the 3' king coilovers on the front.
Another oil change.
Air filter.
Trans again.
Glad to see that you were keeping 'hydrated' during the snow storm. :)
RooTBeeRthe1st
RooTBeeRthe1st
Haha yeah, hydration is important! That was actually just for the pic. I emptied that bottle before setting up my bed in the back the night before.
You dropping the pan for trans fluid changes, or pumping it out through the cooler line?
I dropped the pan on the first two after I burned the fluid which is why I did a change and drove it like A thousand Miles and then get another change.
That being said, whenever I finally get around to relocating my trans cooler and probably running AN lines for everything, I'll do another fluid change but try and pump it all out that way I know all of it is fresh.
Denali Brad
How'd you do the Yellow Top secondary? Parallel or isolated?
Bill 1960
Testing the Limits
Is there an ELI5 for this procedure? I want to drain and refill without dropping my AT pan.
I had to search that term to find out what it meant LOL.
I have seen it written up on numerous forums over the years and I’m sure it’s on yew tube. It’s not difficult: disconnect the cooling line at the radiator and then idle until it spits a little air; shut off. Refill the transmission and repeat until you see fresh fluid draining rather than old. Reconnect the line and then top off to the correct level.
26AT4
