Unhooked Battery, now it won't start- Please help! *SOLVED*
the only thing I am seeing regarding programming is if it won't lock/unlock or doesn't open close properly
I think when the theft deterrent system disables the truck, the power locks are disabled as well, at least that is the way I remember it. I have never had it happen to me, so am just going on what I have read.
my 2012 has a glitch, when you disconnect the battery and reconnect it triggers a security communication issue and it will not start and will not illuminate the security light, everything else will work including the door locks, the only way to see the error is with a tech2. the fix is do what I noted above disconnect the battery, hit a few buttons and switches to clear any residual power out, hook it back up and start it.
S
Scrapman
then disconnect the battery cables, leave them off, go put the key in the ignition and turn it to start a couple times, flip the headlight switch a couples times and step on the brake pedal a couple times, then hook the cables back up and try again.
Gave it a shot. Nope. When I first turn the key, I get the message 'stabilitrak off" then "traction control off". None of the small gauges like the voltage are working either.
also people replace these all the time it's plug-n-play, so unless you have a issue with it working properly afterwards i.e. lifting part way or not unlocking/locking, then it doesn't require programming
what is your battery voltage with the key in the run position? and by this I mean at the battery not whatever it may show in the cluster.
BG1988
disconnect the battery again, touch the battery cables together for a few seconds, hook them back up, try to start again.
don't touch the battery cables together
this might be fine on older cars 1991 and before, but modern cars with 100s of computers this is a bad idea bad things can happen if one of the modules have a broken diode (reverse current protection)
it might damage components in the electronics
disconnecting the battery and turning on the hazard lights will discharge it correctly without shorting the capacitors
small chance it will pop the filament but a 5$ bulb is cheaper then a 350-400$ computer
S
Scrapman
12.15 volts with key in run position. 12.22 with key off.
if the voltage is above 10.5 then try reaching under the edge of the underhood fuse box and jiggle the wire harness's that go up into the bottom of the fuse box
if the voltage is good then you have a bad connection somewhere something is wet or got corroded, you might have to start looking all over but your prime suspects are going to be the battery cables, starter cable, fuse box & harness, ecm harness. body grounds.
and just for s@hits& giggles, start checking each fuse, only takes a couple minutes on the top of each fuse is 2 metal tabs, put your meter on continuity and probe each fuse
S
Scrapman
that is a discharged battery
It was higher when I started jacking with it at about Noon today. I have checked all the fuses under hood and in the cab, and even charged the battery with my truck. I have had Zero battery problems until I unhooked it today.
it is like one of the computers (BCM Maybe) turned off and isn't coming back on.
I need to find a shop manual and electrical diagram and dig into them. I have only owned this Tahoe for about a year, but it was well taken care of. The engine is cleaner that my wife's one year old car.
wsteele
There are a ton of YouTube videos on ways guys got their Theft Deterrent system straightened out. The ones where guys stand on one foot holding their breathe I probably would skip.
One constant in most I scanned was the battery needs to be kept charged, the tow guys all use jumpers during their procedures. I would probably get and keep that battery charged up (should read 12.7+ after a charge). The charge state should be taken with the battery disconnected from the truck or quite a while after shutdown, lots of parasitic drag as things spool down that will look like a low charge state.
The 30 minute key relearn procedure is probably worth a shot.
S
Scrapman
There are a ton of YouTube videos on ways guys got there Theft Deterrent system straightened out. The ones where guys stand on one foot holding their breathe I probably would skip.
My security light is Not on. Your saying do the key relearn procedure even though the security light is Not on?
S
Scrapman
Don’t sound so incredulous you’ve tried everything else….
I wasn't trying to, but the key relearn procedure uses the security light going off to relearn the keys. How am I supposed to do it if the light isn't on?
wsteele
I understand your security light is not on. You told me that before.
What I am suggesting is something in your BCM/PCM is not happy and given you were screwing with components that talk to the BCM and interact with the Theft Deterrent system, perhaps a procedure that resets programming in those modules may clear the state you may have induced.
As I posted before, there are tons of YouTube videos that document n number of ways to reset components in this logic train. One likely will work for you.
good luck.
wsteele
So make it 13 minutes between off/on/start cycles. Or maybe try in succession the procedures documented in the first 19 YouTube videos that address similar problems.
Without a high end two way scan tool, it is going to be a kind of blind man’s bluff thing.
It is possible it isn’t even a theft deterrent problem. It could be a fried liftgate control module, BCM, PCM, crank relay, etc. etc. etc.
BadDaddy2003
