67k now. But a worn hub on the rear? I believe you’re thinking of the front? In the rear the tone ring is on the axle shaft and the sensor mounts in the axle tube.
Front hubs are brand new Timken. And the code always says LR wheel.
long way to go before thinking about a rear axle, could maybe be dirty, be sure to use a good quality tool on that retaining bolt it will be on tight and has factory lock tight on it.
pwtr02ss
Tennessee
Reading>me.
Sorry. Yes, I was assuming the front. Continue...
Bill 1960
Testing the Limits
Has anyone any experience with GM’s warranty on parts? Two months ago I had a dealer on the east coast replace a window regulator RF door. Now that I’m on the opposite side of the country it’s dragging and needs help to close, just like before.
Just wondering what the response will be when I take this to a dealer out here and request a warranty fix on that window?
Bill 1960
Testing the Limits
Took the Hoe to a local shop for an oil change today (I do my own at home but we’re on a road trip). As I write this there’s four guys under the Hoe :dogpile:
I don’t know if it’s a training session, or if they’ve never seen a lifted Tahoe before…
Hopefully not discussing what they just broke! :eek:
RooTBeeRthe1st
No matter what the reason, it can't be good
wsteele
I think it is generally 12 months.
if you have the receipt, it should be no problem, if the dealer did it, it should be in the system and shouldn’t be an issue at all.
wsteele
Or how to break you the bad news.. ;)
Just show them your receipt, gm warranty is good nationwide. As long as you have the receipt.
Just Fishing
Can't fix stupid
Utah
Yup, i would have wandered on out to see what the hubbub is.
You don't want surprises later.
But with me, i have had some really bad experiences... lol
Just Fishing
Can't fix stupid
Utah
And i changed the oil filter...
Yup pan is coming off.
Bets if it was the high flow oil pump sucking air because of too much flow?
Possibly ran a crank or rod bearing dry...
I'm just hoping it's not a cam bearing, and that i don't have to pull the engine. :(
Just Fishing
Can't fix stupid
Utah
My goal this weekend is to powerwash the under side and get the hoe up on jack stands.
Got some good rain the last few days, noticed a puddle of sand from my property forming in the garage.
So i need to get the undercarriage as clean as possible.
I hate getting dirt in the eyes, ears, nose, and mouth when working under a vehicle.
wsteele
Where I take my Yukon year round means I never get it totally clean underneath. I pressure wash it occasionally and always use the car wash that has a double undercarriage spray setup.
When I recently did my O2 sensors, it was like walking into a sandstorm. I started with safety glasses and ended up with monogoggles over them. You think you can reach up and not rub anything causing the shower of sand...
put in 25 gal of mid-grade @3.91 on a 7-11 app special, best price around, lol price gap between stations around here is .91 cents
costco has premium @4.09 best price
87 is @3.85 also at 7-11 best price
no corn around here, although one station in the next town supposedly has 1 pump but never go up that way.
Trey Hardy
Picked up some 22x14 two piece fuel Mavericks and 35s to go with the new lift kit
wsteele
Not bad for Cali. I paid $3.87 for 87 E10 at Costco yesterday. Here, the only close E85 pump the guy just sets the E85 price at what Costco is selling E10 87, so other than when I am dicking around with my virtual Ethanol content sensor errors, it makes no sense whatsoever to buy E85.
I suspect if they were making E85 out of potatoes, it would be everywhere here and cheap... :)
RooTBeeRthe1st
Looks like they're planning a Pearson station...blue stations are supposed to be exhausting.
Propel is no where near though.
The Whip
