Painting center caps
Blackdrag450r
anyone black out their center caps? Are they steel? Do they have to be stripped first? I have access to a blaster but have had troubles with chrome in the past.
Thanks
kbuskill
NE. FL.
If you want to paint chrome... sandblast it first then use a "self etching" primer and then paint.
Works great without issues... it's all in the prep work... lol
Blackdrag450r
Blackdrag450r
Do I have to blast the chrome completely off? I have had issues in the past with not being able to get all of the chrome to come off.
Lightning 95
Plasti-dip rubberized spray will stick to clean chrome great. I use it all the time, and you can simply peel it back off.
kbuskill
NE. FL.
No... just enough to scuff it up and help the self etching primer to get an even better bite.
Lightning 95
That's the best thing about Plasti-dip, no scuffing or primer needed, just spray it and it will stick.
kbuskill
NE. FL.
Plastidip is definitely a great product... I have used it on lots of chrome pieces on my motorcycle before. I just assumed the OP wanted a permanent solution.
cj6913
Detroit
Sorry I just joined, but you can soak the center caps in easy off oven cleaner. The lemon stuff. Does not hurt the plastic and takes all the chrome off. Just wash real well with some warm soapy water afterwards.
kevlac
Orion Twp, MI
I used Plastic-dip on the caps. I cleaned them first with denatured alcohol. The caps came out great. For the wheels, I used Rustoleum self etching primer and antique brass top coating.
Jbirdstruck
ATX
I had mine powder coated a couple of years ago. They still look great! Make sure to do the bolts that hold the caps on as well.
Sparksalot
Bastrop County, Texas
I did mine a couple of days ago. With theothertwin for comparison.
Drewphil
