2014 PPV - Ontario
ppvfan
Ontario, Canada
So I picked up my 2014 PPV from a local police force in Ontario today. It was purchased through govdeals.ca 224,000 km on it and I was the only bidder and got it for $5500 CDN.
My initial observations.
No lifter noise. I plugged in my Range AFM before the trip and hope it stays that way.
The tires are Eagle RSAs with good tread left on them. I found the ride on the highway to be good. Not too noisy. However, I have a a vibration at highway speed so I think they might need to be balanced. Is the Road Force balancer best for these?
There was excessive bouncing over bumps. I think that the shocks and struts could use changing. There are new springs in the back.
The interior is a mess. They dropped in a middle seat/console in the front. Not attached to anything. Not sure if I'll keep that.
There's a brand new back seat too. Just sitting there with no nuts holding it down. I think I'll have to get that attached before the safety inspection on Tuesday.
The driver's bottom seat cushion needs to be replaced.
All kinds of holes, missing handles, trim pieces etc. Nothing too bad.
The hubcaps are missing and need to be replaced. The lower trim on the front bumper is chewed up.
I replaced some bulbs and the only light I can't get to work is the LH brake light. Any tips on this?
Aside from that I'm happy to have it and look forward to driving it and doing some work on it.
Miami-Dade
Moderator Supporting Member
Welcome from Miami Beach!
Your 2014 PPV looks overall in good condition. You got the best color IMHO. Having the tires road forced worked for me with vibration in my 2016 LT.
Bill 1960
Testing the Limits
Welcome. I am generally averse to Chinese counterfeit parts but occasionally I will buy them if it’s a cosmetic part. The OEM plastic hub caps are obscenely expensive. I got four new ones on EBay and they cost less than one OEM.
P
ppvfan
Ontario, Canada
Thanks for the info. Today I have to get the left brake light working. I'll check for power and if that doesn't work I'll do as someone here suggested and run a jumper wire from the right side.
Where the two back seats overlap at the front it looks like the seat mounting leg on the larger one is bent as the hole doesn't line up with the bolt on the floor. May have to do some bending. I stopped at a Chevy dealer and the parts guy provided some 12mm nuts that fit the floor bolts.
P
ppvfan
Ontario, Canada
The brake light problem turned out to be a bad socket. I'm ordering a new harness but did a quick fix for the inspection. I covered it with electrical tape as well.
The 2nd row seat just needed to be wiggled around until it fit over the bolt. The 12mm nuts worked.
However, while doing all this I noticed that the LH seat belt buckle was for a center seat and did not fit the seat belt. Hmm. The RH buckle end was missing completely. So I started looking for 2014 buckle ends online. None of them, nor the 2nd row seat matched what I had. Long story short, I have a 2016 2nd row seat in my 2014. I suspect that the guy who bought the 2016 from the same department has a 2014 seat in his.
Without any other way to check, I'm going to order 2 GM 84600044 buckle ends and assume the 2014 seat belts will fit in them.
The right front strut is definitely worn out and the left is leaking. Any recommendations for replacements? Are there specific PPV quick struts available? Thanks.
Sparksalot
Bastrop County, Texas
I had to replace the front shocks on thecopcar recently, but wasn’t able to find complete struts. I ended up dissembling the struts and putting new shocks in.
P
ppvfan
Ontario, Canada
The safety inspection found the following items:
taillights crazed and/or moisture inside
seat belt buckles wrong/missing
one front control arm
rear calipers
oil leak from pan gasket and oil cooler line area
and a few other things
The front struts passed. I will replace those in the near future. They wanted about $1,000 to change the oil pan gasket and cooler lines. I decided to try Blue Devil Rear Main Sealer for now. I put it in earlier today, drove a bit and there is no trace of a leak from the two trouble spots. I've got a piece of cardboard underneath and will check it tomorrow. I'll change the pan gasket, lines, O-ring and add the AFM diverter on my own instead.
Everything except the taillights and seat belt buckles came to $2700 plus tax. Not a giant surprise considering it has 220,000 km or 140,000 miles. If I can knock off a thousand bucks I'll be very happy.
P
ppvfan
Ontario, Canada
Looking for advice on a couple of things.
1. The front bumper is missing the air dam and is a bit ragged as per the photo below. I don't think the tabs at the bottom can be fixed so I'm thinking of cutting them off to make it look a bit cleaner. I may get a new bumper cover and air dam in the future.
2. The vehicle came with a center console jump seat. However, it was just sitting there and is missing the 2 steel frame pieces to attach it to the front seat bolts. These don't seem to be available anywhere so I'm looking for ideas about what to do with this. If I can secure it to the floor somehow I'll keep it.
Thanks for any ideas.
cj6913
Detroit
These guys might be able to help.
P
ppvfan
Ontario, Canada
Those look good. Thanks.
CobraKing
Congrats on your vehicle purchase. I picked up a '14 in about 4 years ago with 204K on it and I now have 264K on it.
If you can replace the O-ring on the oil pickup tube when you can, that'll keep the oil pressure steady on the vehicle.
I replaced my front and rear shocks last week with the OEM AC Delco parts - which surprising weren't terribly expensive and the truck is riding amazing.
Your u-joints might be shot, hence the vibration at the higher speeds - I also had mine replaced last week and the vibration at 120-129KM/H is gone.
Wish I had done the shocks and u-joints much, much earlier.
My driver's seat cushion - bottom and back rests were toast and I got the OEM cushions via https://www.tubmangmpartsdepot.ca/. Took about 2 hours to replace them taking my time and the seat feels so much better.
Other than that just change your fluids and plugs if they haven't been done so for you already.
P
ppvfan
Ontario, Canada
An update of where I am so far. Still not on the road but getting close.
I reassembled the liftgate handle with a new switch and put the interior panel back on. It works!
Took apart the LH passenger door and added some Kilmat to the exterior door panel.
Loosened the door lock actuator so I could add my new locking rod. Closed everything up and attached the lock tab. That worked as well.
I still have to do the right door but that should go much faster.
Best News
Discovered where my 2014 2nd row seat is and arranged with the guy who bought the 2016 PPV with my seat to meet and trade seats. That should solve my nagging seat belt issues and get me almost ready for a safety inspection.
P
ppvfan
Ontario, Canada
The last piece of my seat belt puzzle is finally figured out. I was able to attach a 2014 LH passenger seat belt buckle on both the LH and RH side of the 2016 seat I have. It is a double buckle and since there doesn't appear to be any extra room in there I'll cut off the unused side of each.
I also spent some time removing rust and painting the affected areas of the front fenders. They will look good at 20 feet or 20 mph, whatever the old saying was.
As of next Thursday I should be able to finally get this saftied and on the road.
Towmaster
