2015-2019 GMC Yukon performance full LED headlight
Bulldog5
Heck yeah. Ended up brushing it with Maguire's & mineral spirits then hittin the rad with rustoleum.
The plug wires showed up yesterday ended swapping those. Noticeable difference after 100K+.
Would have been easier with the drivers side 33x12.5 off instead of going around it. The plugs went out/in ok though sitting in a chair. Used a ball-swivel head ext get #3 and then a 1/4" fuel hose at the plug end to fish around the steering shaft and in. #8 under the PS firewall sucked. Ended up using the fuel hose to fish that one in too. Two 1/2" ratchets - a torque & a shorter with a single 3/8" extension got 8 out/in but wasn't easy.
Put the lower tow hook valence in Friday night also. That seemed about as fun as the spark plugs. Broke one of the fog light clips but all holds together tight. Good time to clean the frame a bit with those wheel liners out. Ended up doing lazy-job just hitting what made sense with the rustoleum. Will definitely need to strip'er down again before winter and do everything before the salt wins.
Truck looks great - what tires are you running BTW?
I just did the same: upgraded LED headlight units and same grill (ebay?). Did you get your emblem to line up nicely with the grill?
Looks awesome bud!
BeenChevy
Minnesota
Looks awesome bud!
Thanks. Tires are atturo trail blade. Grill is ebay and no the emblem standoff had to be trimmed down quite a bit. Ended up using black flex seal to re-form the standoff and make it flush without any rattle. What did you end up doing with yours?
Bulldog5
Emblem is just on there and not well aligned. Will be taking back to get the back shaved off.
DenaliBQ
haw are the lights working out ? anyone else have some more pictures of the headlights on your trucks would love to see more
BeenChevy
Minnesota
I think there's notable improvement over the stock HID's. Want to figure out an "8-HI" mod and keep the fogs on when switching to the hi-beam though.
Installed a cam and uploaded this clip; backing out a driveway that shows them off a bit and then out of a small town, eventually onto the freeway toggling the brights near the end of the clip: https://drive.google.com/file/d/1a7g3NyORRcYrl88E9nEhlcBbK8JeOJms/view?usp=sharing
Bulldog5
did some night driving and the lights have improved the experience 1000%. Stock HIDs at night poor - these lights are incredibly bright, the high beams work perfectly (auto highbeam works). I have the LED fogs as well and they do a great job of lighting up the road in poor weather as well. Highly recommend for a plug and play solution. Fitment could be better vs. OEM but the performance outweighs the small issues with fitment.
BeenChevy
Minnesota
Drove 20+hrs from MN to the east coast MD and 20+ hours back deciding the hi-beams aren't sufficient and low-beam+fogs are better. The hi-beam LEDs don't cast far enough, are too narrow, and look too blue making it easy to over-drive them at 70mph and tougher to see big game until you're on top of them or they're in the middle of the road. Since (like most stock setups) the fogs go out when hi-beams are triggered, this compounds the problem of losing site of the ditch and about 30'x30' in front of the truck is muted real quick. Thinking of moving the fog sw to a separate relay to battery to keep them on when using hi-beam. That or try and flush mount a high-end pair of square pods between the tow hooks.
Bulldog5
Hi-beam working well for me. This is driving through the rocky mountains...
dfatownsend
Any other or new opinions on these lights from you guys? It’s been a few months and curious if you’re still satisfied with the XB’s. Seriously looking in to buying a set. Suggestions??
BlackYukon
I'm kind of a Retard
My 5 month synopsis is that they aren't as bright as I was hoping they would be, I may have just gotten a slightly dimmer set than others, but they aren't as bright as the Diode Dynamic SL1's that I had in the stock assemblies. other than that I'v been very happy with them. I would definitely purchase them again without a doubt.
BeenChevy
Minnesota
I agree with BlackYukon, the low beams are not as bright as I had hoped but still an improvement over the stock HID. Although, I have several other vehicles that produce better light output but with 55w HID's in comparison. It's very easy to out-drive the low beams at 55mph. The hi-beams are not great and cast a 6000k bluish color range that make things appear foggy at a distance compared to an HID. I'm now looking to fab custom projector housings that will run somewhere in the bumper. My plan will be to install 55w HID's in 3000k yellow as I have on 2 other SUV's that make a word of difference.
These XB's do look nice though and make the truck a bit more unique looking. Can't say I'd spend the $$ again for these though. The fit isn't exactly perfect either making the drivers side sit slightly off seem but you can't tell unless you pop the hood and look close. They do hold up in the car wash well. So far I've had zero fogging issues.. winter is right around the corner though, so we'll see.
Xsbank
Morimoto makes crappy nice stuff. The fog lights I put in my F150 are useless and like a Liberal, I still bought Morimoto fog lights for my Denali and they are also very nice but they are useless as fog lights. Be very afraid of Morimoto, they offer lots and deliver very poor light, which is really what they are supposed to be selling.
I really regret wasting my time with Morimoto, not only because their useless stuff is on my truck but I also regret all the time I wasted making their “plug and play” crap actually fit. Now I will have a really hard time selling this junk.
DenaliBQ
can you post pictures of the fitment issues ?
DenaliBQ
FYI just got mine and installed them and couldn't be happier ..... yes the fitment gaps could be a little better but as far as brightness way better then my hids and when compared to my 2020 acadia led headlights the brights are better then them as well
L's Truck
DC Metro
So my left headlight has been taking on moisture. Appears one of the seals between the lense and housing is bad because it happens even when it doesn't rain. Debating between contacting TRS, using a heat gun to fix it myself or just removing them altogether. Sucks because it is an attractive light.
BlackYukon
I think these come with a 5 year warranty. It might be worth it just to have it replaced with a new unit.
X-ray Nerd
