Taller tire on 18” stock wheel
Gmfm
Time for new tires. I have a 17 yukon slt with stock 18’s and stock height with 265/65’s. Most of the bigger tire threads include rigs with leveling kit. What are some taller tire sizes that will work to help fill the well?
Big Mama
Virginia
Welcome to the forum from Virginia. Try tire rack’s tire size calculator to see how other tire sizes compare to yours.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components and different wheel widths and offsets, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
vcode
Your website calculator leaves out one very important measurement that is usually the limiting factor on our trucks......horizontal clearance from the tire to the plastic fender lining. I.E. do the tires rub the fender linings when you make a turn. I would venture a guess that most issues occur there.
vcode
I think a lot of guys have run 275/65's with no issues as they are only 1/8" taller than the 275/55-20's that came from the factory.
As stated in my original reply, the calculator worked for me, including the fender liner clearance. Of course, everybody's experience is different, but eliminating a rub with the fender liner is generally very easy to fix.
G
Gmfm
Ok thanks. I’ll probably be shopping for some 275’s
K2 Kaiju
The Depths
265/70/18 with a 1.5/.75 mild level on stock LT 18s...
Drewphil
