05Single
afraid of the dark
- Joined
- Feb 26, 2015
- Posts
- 8,244
- Reaction score
- 11,648
Nope as it sits flush on the metal bumper. I wish there was an easier wayBut could you cut 1.5” off the bottom of the bumper cap?
Do you Have to install the HD grill or can you just use stock Tahoe grill when installing the HD hoodyou will need an 00-02 Silverado HD hood grill bumper, grill, and the bumper brackets.. the HD bumpers hang lower than the non HD.. 1lowhoe04 has a write up somewhere...
I used an HD grill with my stock bumper pad. I did need to trim the bottom of the grill.I believe the bumpers are the same. It is the pad on the HD trucks that is thicker/taller, and why you would need to use an HD grille if you went with the HD bumper/pad. The HD bumper/pad is taller because HD trucks are on a 2" lift to accommodate the Allison transmission many were equipped with.
