making your engine look pretty
ndavis0001
Davis Motorsports
Jacksonville, FL
WD-40 dont have to wipe off of anything. learned that trick a long time ago on outboard and inboard boat motors, been doing it 7 or 8 years on all cars i detail and my own.
Fauxnali
Gold Member
Edmonton Alberta Canada
Doesn't applying WD-40 make it all greasy giving more dust something to stick to?
In my opinion if it is clean and grease free the dust will just rinse off with a water hose or you can blow it off with air.
txhoescrapin
Our needy member :-)
Burleson TX
No wd 40 repells dust, won't allow it to stick to things, simply blow it off with air compressor.
puckhead
CO
Gonna have to try this WD40 thing. Think it works better than say a good foaming tire cleaner?
blueflamed03
Oklahoma
I use it on inner fenderwheels, clean, and black :)
baron
i remember looking at a car for sale once and the engine was amazing looking. the dealer (used car lot) told me they sprayed gas or kero on the motor to make it shine up. wtf?!!
Both come from petroleum, which is the same place you get parrifin wax, among other things. I couldn't say that gas would shine it much, but it would certainly clean it. Cut right through tar, grease, etc. It would probably end up drying it out a bit worse than armor all too. Kerosene, on the other hand, if you have ever felt it on your fingers, it is fairly oily still. I could see how you could shine with that stuff in an engine bay. I don't think it would be any where close to ideal. I, personally, don't know if Armor All is still really bad for your plastics/vinyl, etc, but at one time, it was pretty rough on them if you didn't keep reapplying. It would really dry them out. I haven't touched the stuff in years and make sure that no one puts it on my cars. I have noticed that tires from the used lots start to crack sooner than even old tires I have, after they have put Armor All on them. Might just be a coincidence. As far as spraying under the engine bay, like people say, make sure to stay way from electronic looking areas. Not much worse than sitting at the car wash, trying to get water out from your distributor cap.
kickitandholdit
GA
damn thats clean. i pressure wash all the time cause i ride dirt roads alot. be easy on the electronics and avoid the air intake and you wont have a problem.
Fauxnali
Gold Member
Here's the engine all Painted and WD'd up. Did the fender wells too. Pic doesn't show it to well but yeah it does keep the dust off.
Thanks for the tip!!!:Handshake:
puckhead
CO
did you wipe any WD40 off or just let it dry up itself? Looks great bud!
puckhead
CO
Makes sense, probably the best thing to do too
puckhead
CO
hey, no problem! Its clean rides like yours that give a lot of us the motivation to go out and do some more to make our rides unique
CKendrick
