The reckoning has arrived - big $$$
intheburbs
intheburbs
SE MI
What did the engine run you? My 08 express van has the 6.0 in it so I’m expecting it to have a similar engine as this. Runs good for now but something is telling me to prepare for the worst
GM reman long block - unfortunately a dealer-only item, $3869.98 is MSRP, and that's what I paid. Part number 19209705.
Labor and some miscellaneous/opportunistic part replacements (oil and trans cooler lines - easy to replace with engine out) - brought me to $7460.
$5k in parts including the engine, $2100 in labor, and sales tax.
That is why it is called a parking brake and not an emergency brake.
I'm not worried about parking, just the truck. The pawl can handle it.
And when I tow, I always have chocks with me. In the rare circumstance that I have to park on a grade, I chock the trailer wheels, put it in neutral and release the brakes, letting the chocks do all the work. Then I put it in park.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I like things that work the way they should and for what they are designed for. I am weird that way. Your rig, your call.
intheburbs
intheburbs
SE MI
I'm the same way. But if I haven't used/needed something in almost 8 years, that's a pretty good indicator. I'm throwing close to $10,000 into this truck. In this case I'm going to make an exception.
Again, your rig, your call. If you are throwing $10k at the truck, then why not a fraction more to fix this problem. The answer is, "It's not a problem to you". That is what counts.
If you are throwing $10k at the truck, I assume you want to keep it. This is a leading question now,
When throwing $10k at the truck, are you only fixing or replacing parts that are worn out or broken or just not working or are you going to be replacing any parts/components that you want to replace, "just because"?
In other words, do you only replace components/parts when they break?
I plan on keeping my Z71 and I have been THROWING $$$ at that rig to get it in tip top shape. My radiator does not leak but I am replacing it. My control arms were working but I replaced all 4. Way easier to do now than when it is a surprise breakdown.
That is what makes the world go round. We all approach these decisions from different directions.
intheburbs
intheburbs
SE MI
Going to overlook the DB tone of your post....I take care of my shit, your insinuation to the contrary notwithstanding.
The engine lost oil pressure. We thought it was the pressure sensor. It wasn't. In the short time we ran the engine doing diagnostics, it shit the bed.
2500 trucks are insanely expensive right now, so I decided to throw a new engine into it because I plan to keep it another 100k miles at least. If I wanted a used 2500 replacement truck with 100k miles (the mileage when I bought mine in 2013), I'd have to fork over $25k or more.
While the engine was out, we replaced other parts that were not failing but starting to show their age - oil cooler lines, trans cooler lines, coolant crossover tube, etc.
The braking system, except obviously for the parking brake, is 100% functional and still had plenty of meat on the pads. But the driver's side front pads were more worn than the passenger side, indicating a potential problem. Since the truck has 207k miles, I figured I'd just replace the whole system - power steering pump, master cylinder, rotors, calipers and pads. Overkill? Probably.
The engine broke. You gonna replace yours as a preventative measure? I don't think so.
Were the oil cooler lines failing? Nope
Were the trans cooler lines failing? Nope
Was there a problem with the coolant crossover line? Nope.
Was the master cylinder broken? Nope
Was the power steering pump broken? Nope
Did the brake pads need to be replaced? Nope
Was there a problem with any of the rotors? Nope
Was there a problem with any of the calipers? Nope (not yet)
Yet, here I am, replacing all of that stuff.
On second thought, I'm not going to overlook it. Take your virtue-signaling, holier-than-thou, high horse condescension and shove it where the sun don't shine.
:cool:o_O
Not agreeing with someone and then telling them it is their call because it is their rig, is something I personally would take with a grain of salt.
You are very funny. Thick epidermis challenged though.
I apologize for hurting your feelings.
intheburbs
intheburbs
SE MI
Finally got the brakes done. Had to hook up to a machine to get a good bleed. The new brakes are awesome. Plenty of stopping power, with a nice, linear brake pedal feel.
Not bad for a 13 year-old with 210k miles...
Parking brake works real good too, right?
intheburbs
intheburbs
SE MI
New shocks to finish out the ensemble. Previous shocks had a little over 100k miles and 7 years. Probably 20k-25k of max GCWR towing.
intheburbs
intheburbs
SE MI
Finally got to play with my Tech 2 for an actual purpose.... Airbag light went on. Front impact sensor. I just replaced the FISs on the Denali, so I wasn't really surprised one died on the Suburban. Bought 2 to replace both as a preventive. I figured if I was going to rip apart the front end, I might as well replace the headlight housings,since the adjuster was broken on the passenger side. Looked at a lot of options, finally decided to stay with stock. The damn impact sensors are $70 each. Ouch. Such a stupid little part.
I wish mine were $70! You're lucky! OE for me was $155 and the Dorman was $99 signed, sealed and delivered. I figured they were both made in the same factory in Singapore with different stickers. How are the leaf spring packs holding up after all these years?
intheburbs
intheburbs
SE MI
I did get the Dorman sensors, but I got them through my buddy's shop - he must get wholesale pricing. Best price I found was $90 at Rock Auto. I want to say the high cost is because they use gold in the connectors (seriously, not joking), but then why do they fail?
Leaf springs are holding up just fine. I haven't towed the behemoth since 2019, so I haven't maxed them out recently, but I've made several long(ish) trips towing my 4k-lb 6x12 enclosed trailer, and she still sits fine with no sag.
And the new brakes kick butt. My father-in-law, a crusty old fart (but a car guy) even complimented the truck that it looks and rides like a new truck. He just recently saw it and rode in it for the first time. Then I told him it was 13 years old with over 200k miles.
My sensor went out when we replaced the condenser. While I may have jarred it, it was split in half from corrosion like the ones I saw in youtube videos. Glad to hear she's still truckin' along!
intheburbs
intheburbs
SE MI
Next up - pre-emptive strike on the fuel pump. I realized she probably has the original units. I bought it at 106k in 2013, and no records indicate it was ever swapped. Taking a few long road trips in the upcoming weeks, don't want to get stranded in the middle of nowhere, so a new front pump is going in next week. Don't really care about the rear pump. If it dies, then I can't get at those 7ish extra gallons. No big deal. My buddy will do it at his shop after hours. I'll help, bring beer, and pay him $150 for his time.
D Rollins
