Non insulated connector was a foot or two out of the main fuse box near driver side firewall. The longer heat insulated section presumably around heat generating source on other side of engine perhaps. I have zero recollection on what they plugged into but clearly there is one (?) on each side of engine.Where exactly was the plug located? Under the hood? Next to...?
I've never seen those round connectors before--doesn't mean they're not for anything. Closest I've seen are knock sensor plugs--but def not those.Non insulated connector was a foot or two out of the main fuse box near driver side firewall. The longer heat insulated section presumably around heat generating source on other side of engine perhaps. I have zero recollection on what they plugged into but clearly there is one (?) on each side of engine.
Yea, I looked too and thought the same till I remembered my new harness that was just installed for my new knock sensors and it looked nothing like that and neither did any O2 sensor harness pics I saw.
Can you see ANY numbers on the connectors that you can share?
OK GOT IT !!!!Inside the grey connector with the lock ring, what does it look like in there? Is it a flat spade plug in or round or whatever?
BINGO! Yes!Might go to the connection at the top of the front shock for auto ride / manga ride
