Mezzo
Very nice! I did the fronts, but not the second row. How hard was that part?
It was actually pretty simple followed this guide step by step and copied the wiring loom and design and made 2 of them, 1 strip sits under the front,and then about 4 feet split off to go to the back seats. Like the guide did I went with chinesium amazon LED strips instead of standard 194 bulbs,and to make sure that the adhesive will last bought a roll of high strength 3M doublesided and cut pieces to fit each strip to make sure it would bond for good since the adhesive that with the strips was absolute crap.
https://www.tahoeyukonforum.com/threads/03-footwell-lights-or-00-led-footwell-upgrades.23834/
treehan77
TYF Fiend
Crestview, FL
Finally got a reply from Goodridge stating they were going to send me some convex/concave washer to fix the leaking issue others have experienced with the center SS hose from their kit 14175. Hopefully it comes soon and is a fix. We shall see! Seems like the kit needs to be updated either way…
Edit: I will post the part # of the washer if it fixes the issue etc if they supply the item number.
Sam Harris
Excellent!! Agree, that washer / spacer should be included in the kit in case it’s needed! I didn’t even think of contacting them, just had another line made, but I’m glad you did.
Thanks, I’ll be following since I have that line in my parts drawer.
ks03
Fool Excess Member
Does anyone make stainless center lines that work out of the box?
Sam Harris
Who has a fire extinguisher in their Tahoe / Yukon / Esky..? I want to have one, but need a solid mount. So looking for suggestions on what anyone else has used.
latvius
Ariton Alabama
I have generic ones like this in both of mine, I installed the bracket at the rear side window frame. So if you looked through the window it would look like it is laying on the window frame (if that helps).
Never had a problem and if I need them just pop the rear hatch and easy access.
https://www.amazon.com/Kidde-FA110-...ocphy=9012869&hvtargid=pla-274770407178&psc=1
Sam Harris
2 minute, $50 upgrade today... I’ll be getting the Grant wheel eventually:
Been on the fence with this one for a while, but after seeing the Grant wheel, and this together, it was a no brainer. I like it.
mattbta
Frisco, TX
Nice. I want to get an airbag with the Bowtie from a Trail Blazer but skeptical about fleabay purchase...if it will even function and what will the condition be? Pics can be deceiving.
What did that one come from?
Sam Harris
Fleabay. Lol
After the recent debacle with the Camaro airbags, and the perma-stamping issues, tbh, I’m more concerned with that possibility, since I didn’t previously have any kind of medallion in front of my face. Meh.
NjA4207
