Had some trouble at Jiffy Lube
rgaffney
VA/GA
I went in before my trip down to Florida to get my oil changed and some other things looked at. Normally I wouldn't go here, but my dad said he would pay for it. When I got down here a message came up that the battery wasn't charging and to have the brake booster serviced. Last year I had the same thing and had to get a new alternator and computer. Well it turns out I needed a new battery and alternator. And on top of that, the oil filter and air filter that jiffy Lube gave me were the wrong ones. The oil filter was a different one so it would only fit in backwards. The air filter was a HEPA filter so it was pointless. Luckily the Chevy dealer in North Palm Beach is top notch and my alternator was under warranty.
I am however planning on raising hell at the Jiffy Lube at home for the ******** they pulled on me
blueflamed03
Oklahoma
wow...that's sad service there....of course, Jiffy Lube was on like dateline, or 20/20 doing scams some time ago on TV......
dropmech
Puddle Pirate
Coral Springs
You'll never even get an apology out of them. They historically do shotty maintenance and for some reason they're still in business. But good luck and let us know how it goes.
cam3439
They probably meant backwards on the threads....maybe?? And a similar thing happened to me with a Champion Oil Lube place. They broke a valve stem, tried to blame it on me (when I wasn't even near the truck when they were checking the air pressure), and tried to use some ****** conventional oil when I paid for synthetic. The only time I take it to a lube place (because I didn't have time to do it myself before my long trip) and they do a ****** job. After they broke the valve stem I stood near the truck as they finished it up. That is the only reason they got caught trying to put some ****** oil in my truck. This was in my old '93 sierra.
I have no idea, thats just what the service guy at the dealer said.
Obviously the dealer is taking you for a ride and knows he can milk you for some big $$. There are no oil filters on the market that are reverse threaded, nor is there anyway they can put an oil filter in backwards on these trucks. The only thing they can do is put the wrong size filter on it. If I were you, I'd get my truck the hell out of there as fast as possible and find someone honest to deal with if you are unable to do the work yourself..
rgaffney
rgaffney
VA/GA
Yeah I mean it's pretty clear I don't know what I am doing. At school I have a place i mostly trust but I would like to do it myself at some point
Bailey-Hoe!
Vermont
man, it is so easy. It consists of opening a bolt, watching oil leak out, replacing bolt, removing oil filter, replacing oil filter, filling with new oil.
I know it can be daunting but watch some one next time it gets done. Then, tackle yourself. You need only 2 tools. Do what I used to do in college before I had ramps, lifts, etc...
Pull the front wheels up in a curb, crawl under and change. It is worth learning. I can say with 100% certainly, when it comes to oil changes, I am way better of a mechanic that the so called "experts" at Jiffy Lube. I have not failed myself yet. Been doing to my own cars since I was 17. Time to learn bro.
rgaffney
rgaffney
VA/GA
Yeah I think I am going to take a stab at doing it myself from now on. Paying someone to do it for me is something that I don't enjoy, being as though I'm in college and I work at Panera
Bailey-Hoe!
Vermont
that's the spirit! Now is a good time to start collecting tools. You can never have too many. Some of mine are bought, borrowed, or found on the side of the road. None are ever gotten rid of!
All you need to do the oil is a socket or box wrench(adjustable works) for the drain plug and a decent filter wrench. Oh an something to catch the oil in. Just make sure you dispose of it properly. Thats the hardest part!
I use Mobil 1 oil and filters. 5W-30 every 5K miles.
Bb
Narco
Atlanta
if youre in the A next time you need it done i'll help you and show you how
Grocery Getter
A guy with a truck.
Phoenix, Az
That's the spirit..... all you need is a 15mm socket or a crescent wrench and if you use a good quality filter it will have a big nut on the bottom you can use a small pair of channel locks on or buy a $5 filter wrench. It takes 20min tops and for the same price as a "jiffy" lube you can be putting top quality fluids and filters in and know it's done right. You can get a set of ramps for cheap, if money is tight check craigslist.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
Hell fire, you don;t need a filter wrench... I do them with my little hand.
The only thing easier than changing oil is filling the tank... NJ and Oregon owners aside.
Bailey-Hoe!
Vermont
Eagle is right. And if it gives you trouble coming off...stick a screw driver through it and turn. You should be putting on by hand, no tools.
BB
General Stalin
I honestly don't know why anyone would go to Jiffy Lube.
I brought my father's work truck to Jiffy Lube last fall by his request because he had a coupon for like $8 dollars off a regular oil change. I get there and find out their prices are OFF-THE-*******-WALL.
It was like $60 or something for a normal oil change for his 2004 Toyota Tundra. That is straight up prison **** with absolutely no lube. Not even a quick spit on the hand, I'm talking bone dry prison ******. You can go to a pepboys and get that done for like $30. My god I was mortified. Of course they were already half-way done the oil change by the time I found out how much it was going cost me so I couldn't decline the service.
Wow.
I always do my own oil changes by the way. It's fast, you know it's done right and you know what oil and what filter is going in your vehicle. Plus it is very gratifying doing your own maintenance on your truck. It is also the most affordable way to go, except I use expensive oil and filters so it's still like clost to $70 for my oil change, but that brings me back to having free range of what you are putting on and in your engine.
Also, as Eagle said, changing oil is a very simple, quick process. Takes like 20 minutes tops, and thats if you DON'T have all the top notch equipment. I drive my truck on ramps and roll around on the dirt in my driveway.
Also, I personally use a wrench to take off my old filter. After driving with that thing on for 5,000 miles the threads expand and get tighter and the rubber seal swells and gets tighter as well. End up being a real wrist breaker to twist off (for me anyway) which is part of the reason why I use K&N oil filters because they have a 1" hex head on the top of the filter so you can just throw a 1" socket on it and wrench off.
yukonjacks
A Vegitative State
The Confluence
Personally I hate messing around with a filter wrench, I buy the K&N brand, theres a nut on the bottom, makes like much easier
Chucktown Mako
I take mine to a local Precision Tune to get the oil changed. They do it for so cheap, I can't do it any cheaper, I don't get oily and I don't have to dispose of the oil. Every time, though, they try to sell you on something which is total BS. I have been letting them rotate the tires too for an extra $10, so it was worth it. The last time though, the screwed up every one of my center caps, bending them all out. I was royally pissed. They also tried to tell me my front brakes only had 30% left on them. I said "Thats funny, I just changed about a month ago." They will try to screw you any way they can. I don't trust the oil change places for anything other than an oil change. Not gonna let them touch my tires and rims again...
HeavyHoe03
