Driveline noise wtf?
called the local driveline shop he said the aluminum gets stressed and will make that noise, not completely sold on that but sounds like the most reasonable explanation.
another video, lot of wind noise but at 1:28-2:10 you can hear it and again at 4:00
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
That would drive me nuts.
ks03
Fool Excess Member
Kinda sounds like a ujoint... but a bad one usually sounds like that crunching / moving by hand, not when installed. I’d probably drop my driveshaft to feel all the joints.
wildcatgoal
Is it for sure coming from specifically the driveshaft? You sure it's not just acting as a speaker, resonating something in front of or after it?
The explanation from the driveshaft shop is a thing but I've never heard of that happening on anything but a drag race car and it was because the shaft was piecing apart inside due to being abused relentlessly by a 800 HP car on slicks.
I'd lean more towards U-joints to start and I wouldn't be afraid to pull that driveshaft and check the pinion, maybe even open up the differential to get a look and see if any metal has chipped off.
Bill 1960
Testing the Limits
WTF indeed. I’m curious to see how this thread ends.
any idea's?
Put the stethoscope on the driveshaft and tail shaft of the trans. I'm thinking u-joint too or a chipped tooth or spline. Shouldn't be anything in the driveshaft tube but that cardboard but what if a booger weld fell off and started bouncing around? The test for that is to put the driveshaft on a driveshaft balancer and spin it up.
Jason in DLH
Cheeseburger and Fries
MN
I’m glad you didn’t drop your phone. Although...it certainly would have given me a chuckle. :Big Laugh:
I had a rear U-Joint break on me once (on a ‘93 Wrangler) with no signs that it was failing. The driveshaft ended up whipping around beating everything up. It was rather amusing. It was a I-6 and I pulled the muffler and put dual exhaust on, so maybe I simply couldn’t hear that ticking noise that you have.
While I have never heard anything like that before, I'm inclined to think it is universal joint related, rather than driveshaft related.
if this was the case I would think the noise would be centered around a u-joint then but this noise is coming from the shaft, which is why I moved the camera from end to end to see if the noise was more at one end than the other.
i'm going to pull it out thursday and go from there
I had a pretty good grip on my phone lol
Glad that you found the source and fixed it. The hollow drive shaft must have worked kind of like a speaker, and projected the noise all along it, thus giving you the noise all along it, when you were checking it out to find the source.
exactly what I thinking, still weird as hell lol
kikeap
