Adding wireless charger to 2018 Tahoe LT
tomas21
Does anyone have the parts and instructions to add a wireless charger to my 2018 Tahoe LT? The console seems to have the model inset in it and the rubber top that would allow for charging.. Haven't opened up back to see if there is a connector available for true plug and play vs. taping into 12v.
Any input appreciated
GranPrix
There's a thread for this but I can't find it. Can anyone link it here please?
Bob2C
Northern VA
OP got in touch with me. I set him up with part numbers and instructions. He is all set
tim crow
Can you post the part numbers and instructions?
Sent from my SM-G973U using Tapatalk
TXZ71
I bought a 2018 Tahoe LT and am in the same boat. Can you please assist?
Thank you,
Tom
Bob2C
Northern VA
ptm82379
Are these the most up to date parts that accommodate the larger phones?
It looks like 19421449 is showing to be the updated one on the gm parts direct website.
RST Dana
OH
I have tried an iPhone 11 max. It does not lay completely flat, but it will indicate charging.
ptm82379
So I see the module was updated by GM. Was the pad ever updated?
If so, what is the new pn.
They sure are proud of the silver tray the pad goes in.
George100
The pad was updated for 2018, the new one has 10 ridges on it and old one had 9. I ordered one with the part number that is above in the illustration but it was exactly the same as the one i had. #23264395. I did update the center console to accept an iphone 12 max. I just got a new tray liner, which is part 84017364 and took my old one and just dremeled the edges alittle and the case and phone now lay flat and charge with no problem. I had the black liner and not the silver (thats expensive) and with the minimal trim it does look good. I just bought a new one to give to the new owner in case they wanted to restore to stock.
ptm82379
Thanks for the tip on the dremel trick. I'm probably going to try it. Does it look OK or did the dremel leave it with a gap?
George100
No, the dremel did not leave a gap, i just gradually moved the edges back all the way around, i just give it a little smoothing. I will try and post some pictures.
For an iphone 12 pro max, the phone does fit at the top of the tray but the edges are bevelled down to the rubber pad, its the bevel i smoothed out. Now i did have the black surround and i really dont know how the dremel will work if you have the silver piece.
ptm82379
I have the black tray. Sure post up some pics if you have them, that would be great!
T
tomas21
Kicking this back one up... leather ripped on our center console and found this replacement that comes with wireless built it. I just need to find a 3-way adapter to utlize the plug powering the cigarette lighter so it can power both the cigarette lighter and this wireless charger.
Has any done this and any idea what type of connect this is in case I can find or make one to be plug and play?
Look at Post #7 in this thread; the connector part number is in the pic.
T
tomas21
Here is a pic of the connector from this new replacement center console with wireless charger.
Durobans
