LOL, I drive mine like a dam sports car, the 6.2 stomps all over the 5.3 obviously you have never compared the 2 to each other.The 6.2 requires premium gas and actually tows less than the 5.3. The 5.3 is not sluggish in any way. I don't think I could justify the 6.2 just for a faster 1/4 mile time...these are full size SUVs not sports cars.
to the OP go test drive a 5.3l and give it a workout, then go test drive a 6.2 doing the same. then make your decision. the gas mileage factor is nill
Also the tow rating has nothing to do with the engine size, the the tow rating is based on the gear ratio commonly used in the 5.3 vs the 6.2 there are 6.2's out there with the same gear ratio and therefore have the same tow rating and if that is really a deciding factor the gear ratio can be changed if so desired.The 6.2 requires premium gas and actually tows less than the 5.3. The 5.3 is not sluggish in any way. I don't think I could justify the 6.2 just for a faster 1/4 mile time...these are full size SUVs not sports cars.
Ding ding ding. Engine size is not THE determining factor for towing at all. I'm sure you can spec and order a 5.3 equipped vehicle to out-tow a standard equipped 6.2, but "the 6.2 tows less than the 5.3" is all sorts of bad info.
Generally speaking, the bigger the engine, the better the odds it has better hardware to tow heavier loads; research would be required to confirm. Either way, NEVER trust what the salesman tells you what you can tow and there is a LOT of fine print for GM claims as well...it's a hell of a lot more than what engine is in there...
Back on topic:
I've also owned both a 6.2 and a 5.3...get the 6.2. Neither is a prius and they are close enough in mpg that the benefits of the 6.2 far outweigh the experience of the 5.3. But as others have said, if this is a soccer mom type hauler, the 5.3 will be fine. But if I had the scratch to where I was cross-shopping them; 6.2.
It's not bad info, it's fact that 6.2 max tow is 8300 vs 8400 for the 5.3.... Considering same gear ratio which is standard across the board on 21s.
Also I agree that MPG is similar, but cost of fuel is not... Premium vs regular. So if the OP is concerned with cost of ownership then that is a factor worth considering.
In the first few years of the GMT900 wagons, the tow ratings were inconsistent too. The Denalis were rated to tow less than later years at first and there were no changes mechanically between them. Might have been that they just weren't sure enough of their product yet. One of the new T1 pickup truck options picked up an extra few thousand pounds towing capacity recently because the engineers said it had excess cooling capacity to handle the extra weight. I think it was one of the diesels.
The max tow wieght differences are negligible anyways when within a few hundred lbs. The main advantage the 5.3 has over the 6.2 high country is lower curb weight and therefore higher max payload. The limiting factors in towing with a SUV are payload and tongue weight and the 5.3 has more capacity in both. I looked at several door jamb stickers on dealer lots and the tahoe/yukon thats most capable of heavy towing is the 2WD 5.3.
My Denali with 700 miles on it guzzles gas like it’s going out of style! I’m getting 13-14. Mainly because I’m always waiting for my wife ot come out of the store, so I’m idling a lot. Can’t wait to take a road trip to see how it does. One thing I’m worried about is the 24 gallon fuel tank. I wish it was bigger. When I seem like I’m on empty it only takes 18 gallons.
Wind is a big factor from what I could see with the 5.3. Going into a head wind I was getting 17 mpg going with that same wind a few minutes later I was around 23 mpg. I was doing 70 mph and the wind was a steady 20 mph.I just returned from a 2500 mile road trip (with a small amount of in-town driving) and got 19.92 mpg with the 2021 SLT 5.3. I first put the odo up against my garmin gps and found the Yukon odometer to be essentially dead accurate. Then I kept track of the gallons consumed. Speed was about 3 mph over speed limit. The dash MPG is about 0.3 optimistic. Overall, I'm pleased.
P.S. The first 500 miles was with stiff headwinds. I'm confident I could have had 20+ mpg without those winds.
