2005 GMC Yukon XL 2500
norcalboon
Northern CA
I had been looking for a 2003-2006 3/4 ton, and since I’m in CA I preferred to find a local 1 owner low mileage option to use as a primary tow vehicle for our 28ft, 6,700lb (loaded) travel trailer. As anyone on this page can attest, the market really exploded for these things in the last year or so - I called 2nd on a few, and the prices have increased almost 50-100% in some cases. But I held out and finally called first on a dealer option they were planning to send to auction.
2005 GMC Yukon XL SLT 4WD with 6.0L and 4.10 rear axle ratio with 90,595 miles. Was a CA Bay Area vehicle, traded in at a SoCal GM dealer. This was my preferred set up, although I would have seriously considered an 8.1L in GT4/GT5 – but for my application I was actually hoping to find the LQ4/GT5 combo.
Decent maintenance history showing frequent oil changes, tires, some other fluid replacements and no major red flags. Good condition, but evident it had been parked outside.
As part of sale, had the following repairs completed at the GM dealer: replace valve cover, timing cover and oil pan gaskets, new oil pan, replace radiator, hoses and connections, new engine and trans cooling lines, differential seal, new rear shocks, new driver side window switch, engine and cabin air filters, wipers, bulbs (as needed), all new fluids (coolant, trans, brake, power steering, differential, transfer case), replace windshield, new cluster, and replace airbag PPS Module and sensors.
Drove it home ~350 miles, it ran great, all temps normal, cruised at 75-80 around 2500-2700 RPM and calculated 15.2 MPG. In limited sample sizes, around town seeing 9.2MPG and one quick tow (50 miles) was 9.7MPG. Seems about what I expected. Towing up a moderate incline it did what I bought it for – held speed and RPM with ease. However, it was a little bouncy. I will play with my WDH – I had to swap back to a shorter drop hitch to get it level but kept it at 3 links which I used before.
I have Timbren SES for the rear on the way, already got the smaller front jounce stop replacements, and will be putting new tires on it very soon. I’m going with General Grabber AT/X tires, but I’m really noodling on whether to keep the OEM size LT245/75R 16E or moving up to a 265/75/16E. I prefer to keep it stock, but these wheel wells are HUGE so I’d also like to fill those a bit more. However, I’m loath to reduce ANY rear axle ratio and this would effectively take it from the current 4.10 to 3.96. The 265’s also are spec’d for a minimum 7” wheel versus the 6.5” OEM. Considering it will only be driven 4-6KL miles a year, and 75% of it will be towing, I want full towing capability and max safety.
Any real-world feedback on running these tire sizes – is it a negligible difference or would I be able to tell? Targeting Yellowstone for 3 weeks in 2022 and will do spark plugs, wires and O2 sensors some point before then. Most other tow trips are few hundred miles mostly within CA.
Any other maintenance items I’ve overlooked or should consider? TIA
S33k3r
Dallas, Texas
Nice rig! Adding an oil catch can and a transmission filter will improve the longevity of the vehicle as well; on the flip side, I have heard of setups lasting 200k+ miles on stock, so you don't NEED to do those things. The only other thing I can think of that you missed was the oil pickup tube and O ring. Those are a common points of failure on these engines; might should have replaced those when you had the pan dropped.
calsdad
200K miles? That actually seems low. I've heard of these going 300k + before needing major work. I had a friend with a 2002 1500 - who had something like 350k miles on his.
Everybody thinks wheels and tires when they think of "mods" , but I think there's a few things that you can do to these trucks that make them nicer to drive and last longer , but they still stay nominally "stock".
I used to have a 2003 2500 Suburban , ended up selling it because it was getting badly enough rusted that I just didn't want to deal with it any more.
Picked up a 2010 Yukon 2500 after that and made a few mods to make it a little more reliable / easy to deal with on a daily basis.
I noticed a few times when driving in REALLY hot weather and then getting stuck in traffic - that the trans temp was headed up to the danger zone. I plan to put a bigger cooler on the truck , but in the meantime when I did the transmission service I replace the pan with a deep pan from PML. It DOES work - I' say it brings the trans temp down 15 degrees or so on the average.
I also noticed that when the truck got up to about 105,000 miles it was really wandering severely on the highway. I planned on replacing wheels and tires because it needed tires and I wanted to go to 20" wheel so I could accomodate larger brakes. So shortly after replacing the wheels and tires - I rebuilt the entire front suspension and adjusted the steering box. That made a big difference - the truck tracks really nice on the highway now. I didn't go with just factory stuff though - I went with an upgraded upper control arm from Cognito, a Bilstein damper, adjustable shocks from Fox, upgrade Idler arm with the weld in brace, upgraded pitman arm, and upgraded tie rods.
Doing all that made the front end nice and tight.
Later I added a set of the big Wilwood brakes on the front (still intend to do the rear).
Doing all of that stuff has made the truck a lot more "driveable" I think. I even drove it in rush hour traffic - where the better braking came in handy a few times.
The chassis on the GMT800 and GMT900 3/4 ton SUVs is pretty much the same. So the same upgraded parts I put on my truck would also work on the earlier trucks as well.
BigDogYJ
Earth
Nice rig! I love ours and don’t see us looking to replace it until I’m forced with no other option. This truck replaced my dually and I haven’t looked back.
The gmt800/900 k2500 burb/xl is one of the most solid platforms around. Hope you enjoy it!
As for your tire question:
Anything larger than stock will likely decrease your mpg. Your not towing super heavy, but it might raise trans temps a bit but that can be addressed with a bigger Hayden trans cooler. Other than that if you really want to keep the larger tires and can’t get temps mileage back in line, your only option is to re-gear. Or get the 8.1
Miami-Dade
Moderator Supporting Member
Nice find on your well maintained GMC Yukon 2500 XL!
Barely see any 2500 in my neck of the woods.
Bill 1960
Testing the Limits
Nice find, sounds like it will serve you well for a long time.
Since it’s a dedicated tow rig, why not stick with the same tire size? I will disclose that on my own 2500 pickup I switched to 285’s and towed a fifth wheel, so it’s not the end of the world with the 6.0 / 4.10.
Phlipnstik
