P0101 + P0300 = ?
cam3439
No problem.
I added in checking fuel pressure above. You can rent tools from autozone or O’Reilly’s to check it.
If you can, post your fuel trim numbers (short trim and long trim from both banks) so we can review them. It may help point us to the right direction. Take readings when the engine is cold and after it has reached operating temp.
T
tlynch
Central Texas
No problem.
Thanks! I'll try to do that today.
Have you tried the simple things like the plug wires and plugs, maybe one or two wires aren’t making good contact, check the plugs to see if one is cracked, and if nothing obvious swap wires and coils to see if the misfires follow the swapped over parts.
T
tlynch
Central Texas
That's a really good idea. I'll add that to my to-do list.
T
tlynch
Central Texas
I did a little data collecting when I made the mail run tonight. Here's what got for LTFT when cold:
Bank 1 7.81%
Bank 2 5.47%
STFT was 0.00% on both banks when cold.
After 15ish minutes of running, LTFT was this:
Bank 1 -0.78%
bank 2 -3.12%
STFT when warm varied between 0 and 5%
I now have my phone set up to graph STFT, so I should be able to show the movement a bit better next time.
cam3439
Based on the data, I don’t feel you have a vacuum leak.
Do the fuel trims start ******* close to or at max value (could be - or + %) when driving or varying RPMs?
Were you able to rule out fuel pressure?
You may also want to rule out the plugs, wires and coils like recommended above by rocket man.
Bank 1 7.81%
Bank 2 5.47%
Bank 1 -0.78%
bank 2 -3.12%
STFTs will show 0% in open loop, with no "trim." Once it goes into closed loop (after warming up a bit) they'll start to show and should vary somewhat, always adjusting. Combine your STFT and LTFT for each bank (so you have a sum for each bank) and close to 0% is best; I think just about any total under 10% will be good.
T
tlynch
Central Texas
Thanks.
I just took the cold observation on the driveway, let it warm up, then made a run to the mailbox. I haven't had a chance to collect FT data on the road, yet.
I have not looked into fuel pressure yet.
I have not ruled out plugs, wires or coils. We'll see what I get done over the weekend.
Thanks for your help!
T
tlynch
Central Texas
Thanks. I'll try to collect better data. Tonight I mostly was just getting the display set up for the app. The little bit of info I got doesn't sound alarming. Nothing over 10%, and combined LT/ST under 5%.
BC
Thanks.
I second the fuel pressure remark.
My 08 Yukon was misfiring and acting up but no hard codes. Would come and go, usually when wife was driving. Mine seemed much worse at around 1/4 of a tank for some reason. Never when it was above half, no idea why that was. Truck was pretty new so I did not suspect electrical especially cuz up here we get a lot of rain and all my previous vehicles that had plug and wire issues always showed up more in the rain. This was showing up on beautiful sunny days with less than half a tank and no codes. In “ugly” mode would mis hard, particularly under accel greater than half throttle. Once, on a whim, I filled it up right away when it happened and problem gone. That really convinced me that it had to be fuel related.
Long story short, put in a new fuel pump and problem gone.
Wish I would have diagnosed more but I was not sure how to do that, I kinda figured that if it were something obvious then the ECM would have figured that out and set a code; doesn’t it monitor fuel pressure?
Anyway, I googled and saw that fuel pump issues were not rare so I rolled the dice and got lucky.
I would definitely include a potential fuel pressure problem for your issue, it would be great to hear from anyone who has diagnosed this type of issue and what is best technique.
Good luck with yours.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Check the condition of the spark plugs on the misfiring cylinders. It doesn't cost a dime and will rule them out.
T
tlynch
Central Texas
Thanks for the info.
I am not able to read fuel pressure using Torque, so that aspect is a mystery.
I have new plugs, and I'll report any changes after I install them.
I also have some fuel trim graphs to post, but work and trees breaking under ice have me a little tied up.
Many auto parts stores have free rentals, so maybe you could pick up a fuel pressure kit. Essentially you put down a deposit on the tool, and that's refunded when you return it in good condition. Unless you take too long to return it, then you've bought it. Check around.
T
tlynch
Central Texas
Many auto parts stores have free rentals, so maybe you could pick up a fuel pressure kit. Essentially you put down a deposit on the too, and that's refunded when you return it in good condition. Unless you take too long to return it, then you've bought it. Check around.
Will do!
T
tlynch
Central Texas
Update 2/26/21:
Sorry for the gap in reporting. What with a week of freezing rain, then a transmission failure, it has taken me awhile to get back to my misfire hunt.
Up to now, the misfire has been a problem on cylinder #4, with a couple other misfires here and there. Today, I didn't bother retest misfires. I just swapped the #2 and #4 coils, and replaced the #4 plug. Once everything was together, and the battery reconnected, I now have a misfire on #6, but everything else looked OK.
Next, I swapped the #4 (was #2) coil and the #6 coil, and replaced the #6 plug. Still have misfires on #6.
It seems odd to me that the misfire moved from #4 to #6, but at least I know the issue isn't plug or coil. I'll try to swap wires tomorrow to see if that makes a difference.
T
tlynch
Central Texas
Update 5/29/21:
I finished replacing all of the spark plugs, and thinks worked pretty much the same. I had a local indie shop take a look while doing an oil change. I filled them in on the whole history.
Basically, they found nothing. Their experience is that intake manifold gaskets are more prone to leaking in cold weather. Shrinkage I guess. In April in Texas, they found no leak. They did recommend buying an AC Delco MAF if I saw more MAF errors.
Eventually I saw another MAF error, so I made sure the new one was AC Delco. I have not had any problem since then. We will see if cold weather next winter brings more woe.
I definitely want to thank everyone who chimed in with helpful ideas. I appreciate it more than you know.
Update 5/29/21:
That was good advice on the MAF. Ive heard of problems with the cheap aftermarket ones.
T
tlynch
Central Texas
I don't drive it much, but it has been trouble-free since the new one went in. That is a welcome change.
I am happy not to spend time trying to rack misfires, swap coils, check for air leaks, and visit with he mosquitos on the driveway.
T
tlynch
Central Texas
Well, the saga continues.
The MAF code returned, so I took it to the shop again. They detected an intake manifold leak this time, as well as knock sensor errors. Both repairs were done, but I still get the MAF error. They are puzzled.
I guess whatever is the ultimate cause is indirectly tied to the intake process. Maybe the computer has a hiccup that makes it freak out about air intake values. Maybe something tied to fuel.
The truck runs OK. I'd be happier without the CEL on.
ScottS-Michigan
