Rear windows won’t roll down
K9Gunner
I have a 2005 Yukon and both rear windows will not roll down. When I use the switch on the drivers door to try and roll them down all I get is a click from each door in the back.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
Do they work when you use the switches on the rear doors themselves? Also, sometimes if they haven't been used in a while they stick. I had my daughter hold down the switch while I pressed my hand/palm downwards on the window itself. They came down with a little help, so I ended up taking the panel off and lubing the gear and cleaning out the window runners. Also, my windows don't go all the way down so it was a pretty quick fix.
K9Gunner
K9Gunner
The rear switches don’t work either. I ordered a new switched hoping that would be it but they still didn’t work
AdrienR
