Front and Rear Splash Guards
RugbyRef
Southern Indiana
Those are great if you want your vehicle to look like a Kenworth....
I'm going to buy the factory ones separately and put them on the back to start. Then maybe engineer my way around getting them on the front.
@Stbentoak - Steve...did you ever get these installed? I'm looking for a set now for front and back, but I too have the retractable step.
Thanks!
Stbentoak
No, unfortunately I do not have a vehicle yet and can't get one on order due to restrictions on options.... I'm going to watch incoming inventory over the next few months and if one shows up somewhere within a 500 mile radius, I may make a road trip to go get it. Just not many Duramax's out there, and most incoming are presold...
Personally, I'd buy the factory ones and put them on the back to start, they try to figure out how to adapt the front ones if at all possible...
RugbyRef
Southern Indiana
Update - I spoke to a rep at Husky yesterday and they are about to release front and rear mud guards for the 2021 models to include an option for SUV's with retractable running boards. We'll see...
dupuis
These are the ones I received for the Yukon xl rears...I saw the word awl and balked LOL
The dealer parts department was no help either after talking to two different people. They sent me to their dealer owned company that does their accessory installations where I had spent already $5K in accessories and they could not find them either. Thank God for these type forums. Thanks again!
Apollo13
I didn't want to create a new post so hopefully a good spot to post.
I just installed my GM mud flaps and i have to say i definitely like how it molds to the body and especially after seeing how much cleaner my truck looks without everything flying and sticking to the sides when i drive.
I found the install very easy especially the front. I would say about an hour to install all 4 and the only reason being is that the back was a bit tight to fit my hands. Dealer i believe wanted close to 200.00 to install (crazy).
I decided to not remove the wheels during install if you are wondering.
AC362
Looks sharp, just got my flaps for my Tahoe and they didn't include the rear instructions! Did you get instructions with yours? I can't seem to be able to find them online.
Apollo13
I didnt but its pretty straight forward once i measured.
You should have 2 pieces for each side. Attach the bracket piece to the truck first (dont forget to use the small metal clips.
Once the bracket is on then you will attach the mud flap on top.
I will try and take pics tomorrow with a better description.
If i recall, 3 screws on the bracket then 3 screws when you attach the mudflap. Dont forget to secure the bottom which you will have to drill in a hole but its really quick.
CASTLEDFW15
North TX
Having mud guards not compatible with power side steps makes some sense. You are risking binding and either destroying the splash guard, side step or overworking/ over heating the retractable steps.
With that said I se only two solutions. 1. z71 Go without and 2 cut off a portion of the side step near the front splash guards. IIRC the rear guards should go behind the rear wheel so shouldn’t be a factor there.
Along those lines……has anyone tried the 2021 Escalade/Tahoe/Yukon no drill mud flaps from Weather Tech? Specifically on any Z71 models…..(MY 2022 specifically)
Any fitment issues since the running boards are a different design than other models.?
Thanks for checking!
CASTLEDFW15
North TX
A few posts late but don’t necessarily give WT a bunch of credit on the 21/22 Escalade/Tahoe/Yukon products.
Two months into production of the 2022
Models and as of a couple of days ago NOTHING for in channel window vent visors. I have them before and they work great Z. Easy to install, and look neat and professional. Installed correctly they look almost factory installed and part of the window frame. I would think by now that could get one or two vehicles to do some R/D and beta testing.
They sell everything except the in channel window vent visors and moonroof wind deflector.
therealbofa
I think Lund has some unless you really want to wait for WT.
CASTLEDFW15
North TX
I know Lund does sell them. They are the vendor for when you order from dealer of GM accessories catalog.
The Lund ones are simply not as good as W/T. AVS…..vendor for AutoZone….not much better…..based on previous experience with other vehicles., roll window up slowly
One of my Coworkers has WT for his entire families fleet of Honda’s…2 Pilots and 2 CR-V’s…….I can’t speak for the pilot but he showed me the CR-V and actually nice. All W/T in channel vent visors use pretty much the same procedure. Line up and center I the channel. Tear about two inches of the red protective tape from the double sided tape and slowly press against the channel. Raise the window slowly over the lip and set in place. Don’t touch the windows for about 48 hours.
The difference with the CR-V is they also provide two low tension spring clips that mount in the channel above the visor. This also provides a guide channel for the window to reduce risk of it catching on the visor. Same concept as the guide tracks on your local car wash except vertical.
Slightly off topic but there are decent products out there. Don’t think I wouldn’t stoop so low as to call W/T, tell them I ordered a CR-V visor but the hardware kit was missing.
Front windows don’t really need that since the visors stick out near the bottom of the window frame.
CASTLEDFW15
North TX
The W/T splash guards do exist…Frony and rear. I have the fixed running boards ao can’t speak for power retractable stop models. I ordered hem for my 2021 Premier but never got around to installing them. Fortunately for this scenario it had a happy ending. The No Drill Splash Guards were sti.l in box and when I took it up to selling dealer for the running board install….(Backorder) they installed the boards, 1st/2nd row floor liners and all four splash guards at the same time while on the lift. Mats and running boards were part of the backorder and they charged $70 even for the splash guards. I will try to get some photos tomorrow.
Shrubs2K2
oHIo
Here's my WT front ones with the running boards extended and contracted. Easy to install. I have them on the rear to but no pics.
HeavyHoe03
