New alternator, flickering lights
Timc9516
Ok so i have a 2003 yukon xl 1500 denali
backstory time. Sunday i had to go to the store so I remote started my truck and when I got in it I seen battery not charging message on the dashing the battery light so I did a short test drive and it started charging again. So I kept going I went to the store did my shopping and when I came out I remote started the truck and it was charging fine. The next day I remote start my truck before leaving for work and when I got in it it said service stability, abs, brake, battery light, and when I cleared service stability it said battery not charging so I reved it up and it started charging. So I went to work and scanned it and I had p1637 generator l terminal circuit and 2 communication codes(which I figured was because of the low battery from not charging) also I checked the generator duty % and it was bouncing from 5% to 98%. So after work I started up and it wasn't charging again so I checked the brown wire at the plug and had 10v unplugged and 1.2 plugged in. Checked the stud and had battery voltage. I reved it up again and it started charging. I went to leave for work this morning and when I started it it said battery not charging so I reved it and it didn't charge so I did a short test drive and it still didn't charge. I don't live far from the shop so I drove to work and it didn't charge at all. So I ordered a reman alternator and put it in after work.
So here's where my question comes in. After changing the alternator and charging the battery every light on the truck flickers at a slow pace at idle and speeds up when you give it gas. My first thought was bad reman so I took it back to advance and had them test it and it tested good so I cleaned the ground and hot at the alternator and the battery and I tested the battery and it read good. I was still getting the flickering so I bought a belt because the old one was starting to crack. And its still doing it. So any idea what the problem could be. I don't have the money to load the parts Canon. And to be honest I'm stumped. I work on school buses and they don't have all these fancy circuits for the alternator
GMT800 2005 Tahoe Z71
Navy Supporting Member
The alternator may test good and show charging but I would bet the regulator is failing. There is a difference between rebuilt alternators and reman alternators. A rebuilt, in my old shop days, was an old alternator that is a core that has components tested and replace or repair what is bad and clean it up and sell it as a rebuilt alternator. A reman alternator is a gutted old used alternator case that is cleaned up and has new components throughout the case. I can't believe that if you told the parts guy what the new alternator was doing, he/she did not swap it out for another one. Get an AC Delco/GM alternator and call it good. Did you have to swap pulleys when you installed the new alternator or did it come with a pulley on it and did you check to make sure was the same size pulley? Make sure the stud(s) sticking out the back and the plug in's are tight and don't move around.
I would exchange the alternator just to rule it out, it could be spiking millivolts, which I just went thru the same thing, mine was sending 18v millivolt spikes and making the ignition reboot affecting the cluster and radio, other times the cluster and tail lights would flicker, did some really weird stuff, replaced the alternator problem solved.
I should mention also that the cables at the battery need to be checked for tight and clean and corrosion buildup under the insulation.
T
Timc9516
Definitely a reman. And it did come with a pulley but I compared them side by side and they were exactly the same. Also I already went through the battery terminals. I always pull the insulation off just to be safe. I'll try and see if they will swap it out tomorrow
Tell them you want it exchanged--don't ask.
T
Timc9516
Also I should add there where two options for alternators a 105 amp and a 145 amp. I figured the denali would have the 145 amp being its almost fully loaded. I wasn't sure how to check. So I went with the 145 and it looked correct. Whats the chance I was wrong and thats my problem?
Gotta check your rpos in your glove box. It'll tell you which you have.
EDIT--Here's mine from my 03 Tahoe--
Mine is just an LS.
Yep, the 145 amp is the KG3 rpo code and the 105 amp alt is K68. I also believe that the flickering may be caused by a failing/failed diode trio. But who knows for sure because sometimes when I think too much I think myself right out of the correct answer. either way, as @Tonyrodz says, tell them you want another alternator and do not ask for one.
You may also want to check all of the grounds in the engine compartment, to be sure that they are clean and tightly connected.
T
Timc9516
Well guys the holidays hit and it was 17 degrees feels like 0 so I'm gonna try Saturday morning ill let you know what happens
Yea, I know what you mean. Cold spell went thru here today. Down to 40 degrees. Looking forward to normal, rain and 45 at least.
Glad it got taken care of by them. It's always good when they stand behind the product with no grief to customer.
Did you ever figure out if is 105 amp or 145 amp?
Well I went to advance today and swapped the alternator and it seems to have fixed it. Thank you guys for the help
Thank you for getting back to us with your resolution. Our collective knowledge base is increased.
bladenbullet
what you were experiencing is called diode ripple...an alternating current leak through the diodes...with a description of your concern the alternator should have been exchanged the first time you brought it in...
the diodes change alternating current to direct current to operate your vehicle...a failing diode will leak a "ripple" on the dc current and can screw up a lot of things...many transmission concerns are alternator related due to the electronic controls...
CKendrick
