2010 Yukon Denali 6.2 exhaust
DRKN57
I just did my 14 Denali with a Supercharger and Kooks 1 7/8 headers, green cats,
Y pipe.. I figured I'd get it all hooked up and dialed in, then do some sort of
exhaust from the kooks back.. But really I knew I wouldn't gain much HP
from an aftermarket exhaust, but I figured I'd def want more sound.
Well, I am going to do Nothing... The stock exhaust is quit a bit louder
than it used to be with stock manifolds/Y/ Cats
And I still have the weird little resonator at the very rear. I'm pretty happy
with the sound right now. I really didn't think it would change, but it did !!
I bet it’s fast!
Javie
Burbank Ca.
I have a Borla S-type cat back. Sounds good breathes good. No supercharger though. Still have kids.
Hey bud couldn't help chiming in on your conversation about exhaust. Are you currently running a borla with your headers?
avalonandl
Troy, MICH & Naples, FL
Which S/C did uou install? Magnuson or Whipple?
Foggy
KS
Looking up my post from this spring, I incorrectly stated that I have the
weird little resonator at the very rear... Well, I don't... I didn't take it off..
The exhaust is totally stock... but apparently my year didn't have that resonator..
I think just the 5.3 may have come with it though ?????
Either way, my exhaust has a pretty good rumble to it with being
stock after the Y (kooks headers w kooks cats and Y)
I really think the new Y design with aftermarket took out a lot of
restriction that the factory Y and cats has
ls1frc
Any dyno, track, or 0-60 benchmarks?
Foggy
KS
Dyno #'s were horrible.. The tune needs a bit of work.. It did about 360Hp & 410 TQ
on a mustang dyno
it's running pretty rich.. I purchased hp tuners and the the tuner school stuff.Just '
haven't had time to do it yet. It's my tow & trip vehicle so I wasn't interested
in peak HP numbers at.. but still disappointed
I'm adding a small squirt of snow meth injection and then doing a complete re-tune
hopefully in the next few weeks. I'm hoping that helps out my MPG
ls1frc
on a mustang dyno
Where are you located? What boost are you running? Was the tune just the stock Edelbrock tune?
One reason I elected to stay N/A was the MPG. Even N/A and ***** footing it, it's thirsty!
Foggy
KS
I'm in the KC area. Didn't do the edelbrock tuner with it. I opted to just
take it to the dyno shop. I'm very dissatisfied with their work. \
I've found a guy about an hour from me that is going to help me ReTune as
soon as I learn a little bit more and have time. It runs decent.. but I know
there should be a lot more efficiency in it. I dropped 5 mpg hwy driving
and even more hwy towing. Edelbrock and the dyno shop thought I would
actually gain a little mpg while towing and be about the same non towing.
ls1frc
I can't see how a blower will gain MPG towing because if it's in boost, it should be in PE. I'd imagine towing it will be making boost a lot because with heavier throttle input the bypass will close.
Now outside of towing, losing 5 mpg likely means the tuner was very aggressive with power enrich.
If you were close by, I'd have a look but I am in PA.
Phlipnstik
