Tonyrodz's Tahoe Build Thread
I actually brought my Tech 2 and showed them how to do the automated bleed. They did it twice that way, and 3 times without the Tech 2. Imo the brakes feel worse then when I went in.
I was there 6 hours! Only thing they charged was for the tires.
How does this look to you guys? Supposedly he couldn't do 1 adjustment because he didn't have a special tool. What kind of bs is that? Does the printout look ok? I have no clue what I'm looking at. I was told my tires MIGHT wear on the inside.
Fu$king clueless rookies!
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
How can I tell which it is? It was fine before he did the rear lines. I hate this coincidence $hit:mad::mad:
I would point to the master over the booster. If you can pump your brakes up with the engine off and the pedal slowly drifts to the floor after doing that several times its the master. If they pushed the master all the way to the floor when they bled the rear lines they could have damaged the seals in it.
I just tried that @George B and the pedal is firm and holding pressure while off.
Sam Harris
I am usually standing there watching them work, a couple times in the last 20-30 years someone went to or did put them on the outside and I stopped them and said I want the weights on the inside. usually it was some young kid, they learn they end having to do the work twice if they don't do it right the first time. Maybe I have been picky about it because I normally always have aftermarket wheels.
Same.
Sam Harris
I was there 6 hours! Only thing they charged was for the tires.View attachment 264951 View attachment 264952
Red means out of spec. [emoji107][emoji2959]
Conedaddy
